Old 04-18-2018, 09:09 PM
taylorjheinzen taylorjheinzen is offline
Default Re: MIDI Sustain Issues
Think I figured it out, but I'll need your guys help! (Thanks for the thoughts so far) The parameter for sustain says "sustain (64)" but every pedal I have records all the sustain data at 128. When I manually move the sustain to anything under 64, it sustains, but without any breaks. Think you were saying something bout that musicman...
Old 04-18-2018, 09:25 PM
The other thing for the OP, could you just post the session (mentioned in post #4) which has the good MIDI playback that was followed by the bad MIDI playback? just need that session with only that track in it. I think a lot of us would have the same sampler instrument so we could see if your session does it on our end[/QUOTE]
https://www.dropbox.com/s/6bpu2tbu4p...0%231.ptx?dl=0
Old 04-19-2018, 04:19 AM
Yes I did a few posts ago. Did you look at the link I posted about the various MIDI messages and what they mean along with their associated parameters? Here is a more succinct link that only deals with cc64 (sustain pedal): http://web.archive.org/web/200707231...ollers/64.html
Have you checked your setup with the snoize utility?
Lastly there is no MIDI data value of 128; it's 127 or below. Yes there's 128 steps in MIDI controller values but the counting starts at 0 (zero).
midi sustain on newly recorded track is effecting all other previous midi tracks awritersparadise Pro Tools 11 1 04-23-2015 11:02 PM
Help midi sustain problem weezamiah MIDI 3 05-21-2014 03:21 PM
MIDI Sustain Keeps Going and Going anackman macOS 6 11-20-2013 05:22 PM
MIDI Sustain Pro Tools 9 ejlucko Pro Tools 9 2 05-02-2011 11:29 PM
Midi sustain setting? play4theworld MIDI 3 09-27-2010 10:10 AM
