PT 12.5.1 MIDI Volume still not usable!!!!
Hi, just gave it a try to use 12.5.1..
Ok, some bugs are fixed, also the MIDI Editor Shortcut is back again, BUT: The use of VolumeFaders is not to work with... While in all of this years, the MIDI Volume directly was send to the Instrument, doesn't matter of Hardware Synt or virtual Instrument, you have now a delay or better, it switches to the new value, when you leave the fader... Completely not usable, if you wanna make a fade in or something else using MIDI Volume... When you record it via Automation, it will play that after fine, BUT HOW CAN YOU MIX SOMETHING, WHEN YOU DON'T HEAR THE RESULT!!! Back to PT 11.... FXXX!!!! |
Re: PT 12.5.1 MIDI Volume still not usable!!!!
Hi, Not sure I totally understand what's happening, but MIDI volume seems to be working fine for me in 12.5.1. Can you describe exactly how your session is setup, what plugins you're using, and the steps I need to go through to try to recreate this?
Thanks
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
the setup is really easy... I create a MIDI track, send the output to a Hardware Synth (via MIDI Interface) or a VI (which is used in an AUX Track)... Note Playing, recording everything fine... When I play, what I recorded, and change the MIDI Volume, it doesn't react smooth..., for example, you start at low volume, try to fade in - no change, until you take the mouse from the fader... then it will play at the last touched value.. When you do that with automation on, and let it play after the fade written in automation, it will do fine... But WHILE you do the fade, you have no direkt control as the volume doesn't correspond to the fader Movement... You can see it also in a Kontakt Instrument... Normally, the volume slider should be moved, when you change the volume on a connected MIDI Track... it doesn't... after written in automation, it does... Under PT 11 no problem, like it was since PT5... |
It's still that bug which was described here:
http://duc.avid.com/showthread.php?t=370866 |
And I doublechecked:
When PT is not playing, and you move a MIDI Volume Fader, no action on the "connected MIDI Instrument". When PT plays and you move the MIDI fader, the instrument's volume switches from the first position to the last one, no smooth fade... Putting Automation to touch etc. doesn't make a difference... When you move a Volume fader on a MasterKeyboard, the volume information will be send to the connected MIDI Device... Hardware and Software...!!!!! |
Got the message from Dan of the AvidSupport, that the BugFix of the MIDI Volume will be implemented into the next update...
So still PT 11..., but at least, good to know!!! By the way, quick and friendly answers from the guys!!! Thanks and Thumb up for that!!! |
Yes. With all the complaining here you would think support was rude. But they're nice guys to deal with and usually very helpful.
Steve
Steve Shepherd Extreme Mixing |
Amazing! It still does't work. My studio is useless with midi volume automation working correctly. PLEASE PLEASE PLEASE Avid fix this now. It is unacceptable. If this is not fixed soon, I will post all the negative things about it every day until fixed on gearslutz and here. Everyone should do the same
VST to RTAS Adapter: Usable on non-MIDI tracks? | Kryst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-15-2006 03:53 PM |
new G5's not usable as HD3 | the dude | Pro Tools TDM Systems (Mac) | 1 | 09-22-2005 03:52 PM |
Roland MPU-IPC MIDI card an OLD one! still usable? | bryanbassett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-14-2003 10:50 AM |
Special paste midi volume to audio volume? | Richard Fairbanks | Pro Tools TDM Systems (Mac) | 0 | 07-30-2003 09:52 AM |
MIDI volume vs regular volume | jimmy fleming | Tips & Tricks | 0 | 03-16-2002 04:17 PM |
