Old 02-04-2004, 07:08 PM
Obscene Obscene is offline
Default Help Please, Buying a Mix Plus
Hey users, I'm buying a Mix Plus (upgrading from the 001...Windows XP) and I was wondering if a Mac G4 450 enough power to us a Mix Plus. If not, what are your suggestions. I'm also looking at a G4 500. What type of results have you guy gotten with these Macs. I just want to know should I go for a better G4, maybe dual processor or is a 450/500 good enough.
Thanks
Old 02-04-2004, 11:13 PM
Noiz2 Noiz2 is offline
Default Re: Help Please, Buying a Mix Plus
Mix ran well on the old 9600 so the G4 isn't the problem...BUT OS X might be. That 500 G4 will be snappy in OS 9 but will probably be slugish in OS X. If your going to OS X (and I imagine you are) I would recomend a DP 1.25 or better G4 or a G5 if that's poss. At the moment the Mix hardware is having some issues with the G5, so if your in a hurry that's probably not the best option. So if you go with the G4 (500) I would look at the CPU upgrades at Other World Computing and go for the fastest you can swing. If your buying new (new to you) I would check out the last of the G4's that are out now, they are pretty cheap and will make your system fly.
www.scottkouesound.com
SK
Old 02-04-2004, 11:14 PM
Oh and OS X seems to really like DP's so get a DP if you can.
SK
Old 02-04-2004, 11:27 PM
Sound Guy Andy Sound Guy Andy is offline
You'll be able to run a Mix+ on OSX with a G4/500 no problem. I'm using an HD3 with OSX on a G4/500 and it works great.
Granted, you'll be somewhat limited as far a processing goes since a Mix+ will become tapped out fairly quickly with modern plugins, but if you're a conservative mixer you'll be okay.
I plan on upgrading to a G5 as soon as the next gen's come out and the prices for current models go down; I want to be able to do more with RTAS plugins (the most popular format for softsynths), and I'm admittedly strapped in that area with the G4/500.
Good luck,
Andre
Old 02-05-2004, 08:32 AM
cybership cybership is offline
I run Panther on a G4/500 no problem. I believe it's just as fast maybe even a bit faster than with OS9. This is not the computer that I use with my Pro Tools rig but as for G4/500 compatibility with OS X you should be fine.
Old 02-05-2004, 10:28 AM
Alécio Costa's Avatar
Alécio Costa Alécio Costa is offline
An used G4 800 Qs with loads of RAM will be paradise to ya
Good luck
Alécio Costa Studio
High-End e-Mastering & Music Production
www.aleciocosta.com
http://www.facebook.com/alecio.costa
PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 1,1 16GB RAM and Mac Pro 2,1 GB
Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter.
Old 02-05-2004, 10:34 AM
TLmix TLmix is offline
If you have the budget, the dual processors do help OSX run better.
TL
Warner Bros. Studios
Old 02-05-2004, 02:13 PM
JNS JNS is offline
I'm running a G4533, 684M RAM, Mix Core, 5 Mix Farms and 1 DSP Farm with OS 9.1 and PT 5.1.1 with no problems.
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Old 02-06-2004, 10:31 PM
Nick Batzdorf Nick Batzdorf is offline
You can run PT on that machine no problem, but a more macho one will allow you to run a lot more RTAS plug-ins in addition to the ones running on your MIX cards. Its screens also won't slow down as much in larger sessions.
I noticed a substantial difference between my last machine, a dual 450, and my present dual gig G4. But it depends on what you're doing. I run a lot of software instruments and always want to insert one more plug-in; your needs may be different.
Old 02-07-2004, 03:42 AM
frenchman frenchman is offline
I use a G4 450 AGP, and to go to OSX I upgraded the firmware, put in an ATI Radeon 9000, a Sonnet 1.2 GHz CPU upgrade, and pushed the RAM to 1.4 Gb and it works fine.
Upgrading the processor has vastly improved PCI bus performance even in OS9.
Mark Haliday
Engineer, Producer
Buying a used Mac Pro. Drew Mazurek Pro Tools TDM Systems (Mac) 13 03-09-2011 12:06 PM
buying a PT 7 PC UK fabpab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-04-2006 06:52 AM
Buying A. Simon General Discussion 2 09-29-2003 08:37 PM
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well xian$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-18-2003 12:53 PM
Buying Mix 24: Which CPU should I buy? Chris Tveitbakk Pro Tools TDM Systems (Mac) 6 11-01-2002 04:09 AM
