Old 07-26-2009, 04:14 PM
paddy303 paddy303 is offline
Default Mbox Mini Distorted output problem
Hi Everyone,
I purchased my mbox mini last november. Over the last few weeks iv run into a problem with the mbox. For no reason the outputs on the mbox becomes distorted. The problem can occur when I start up the mbox or it can occur during using the mbox for a recording session, theres no real pattern to it. Iv double checked my cables and my KRK monitors are fine. Even when im not using the mbox for protools such as watching a dvd or using itunes to listen to music the outputs still become distorted out of the blue. Both of the outputs are distorting not just one. Up until now iv had no problems and I havnt made any changes in the way I record with the mbox. Usually I use a Boss GT-8 For recording guitars, and all my levels are fine, I run it directly to the mbox. This problem just happened over the last few weeks, The only way to get the mbox working ok is to restart my mac and open protools again, when I do this the problem could start right away or it might not start at all, again theres no pattern to the distorting. Im using an Intel macbook-2.1ghz-2gb ram-OSX 10.5.4......and protools 8Le
Old 07-27-2009, 01:45 PM
Default Re: Mbox Mini Distorted output problem
Is there anyone in this forum that might help me with my problem, I would be very greatfull for any advice, sorry for bumping the inital post, I just want to get the problem sorted, Thanks
MBox Mini Output Level Problem ccyuce FireWire & USB Audio Interfaces (Mac) 0 11-08-2013 02:33 PM
Mbox 3 Mini output problem daviddsilvas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-02-2013 11:58 AM
MBOX Mini 3 Distorted Output coopere905 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-15-2012 12:51 AM
PC, Win 7 x64, Mbox mini 2, master output distortion problem jcaval 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-04-2012 04:28 PM
Mbox mini monitor output problem carolpengmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-03-2011 07:55 AM
