Can\'t play back newly recorded tracks
I have been using an Mbox without problem for a few months. Yesterday after I recorded a track I went to listen to it and heard nothing, even though I could see a visual wave form of the track nothing would play back. Tried it again after rebooting PC and same thing. Tracks previously recorded play back fine. I am mysified . . . any ideas? Thanks. |
Re: Can\'t play back newly recorded tracks
A possible solution is to create a new PT Session then use the import session data from the corrupt song. Select copy audio option, that way it will create new files on the drive. Hopefully this may help. Best Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
turn the mix knob to playback. make sure no tracks are solo'ed, raise the volume on the master fader, plug in your headphones.
look for the obvious first.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
I then checked my cables to see if they were the problem when I recorded but they are fine. I also was not peaking when I recorded this so maybe there is some kind of feedbaclk loop going on inside the Mbox or in the software? Any ideas? Thanks. |
After you finish recording a track, take it off record then listen back to it. If the red record button on that track is selected it wont play the audio even if there is a waveform visable. Hope this helps... im not the best person to give instructions.
Very weird.
Today after a couple reboots it starts working again . . . Very strange . . Thanks all for your comments |
Tracks Recorded Into PT9 From Alesis HD24 Dont Play Back | sonicdogg | Pro Tools 9 | 3 | 09-18-2012 05:49 AM |
Audio on newly recorded tracks is out of sync | lectrohowie | macOS | 0 | 04-09-2012 08:12 PM |
Newly recorded tracks play out of sync | Kourquie | Pro Tools TDM Systems (Mac) | 1 | 07-13-2009 04:57 PM |
Newly recorded tracks delayed behind the beat | Fritz12534 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-06-2008 11:51 AM |
Recorded audio will not play back? | MattMacDonald | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-28-2007 05:20 PM |
