#31
Re: -9173 Error Finally Gone?
it takes ton of cash shot from a confettii canon to make this SW work apparently
Hal Cragin On the DUC Since The Year 2000 AD Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2] |
#32
Are you able to run with all 8 cores and turbo boost active? Or do you deactivate one or both? Sent from my iPhone using Tapatalk |
#33
I am hoping the new Mac Pro 28 core with 768GB ram should help reduce the -9173 errors a bit
-Mac Pro 7,1 16core 3.2GHz 96GB -OSX 12.7.2 -PTHDN 2023.12 Ultimate -HD Omni -BM Intensity Pro -Waves Mercury+SSL4000 Collection+Abbey Roads -iZotope RX10 Advanced -iZotope Post Production Suite 6 -iZotope Music Production Suite 5 -HALO UP/DOWN MIX -ANYMIX -Delonghi Perfecta ESAM 5600.S |
#34
Running great for me on MBP 2015. Hardly any CPU drain. No 9173 errors, It did crash once in a 4 hour session. but was back after having 2 min lost, thank you Auto-save. Haven't tried 2019.6 on the Windows machine yet.
Digi002R PT2018 Win 10 INTEL Core i7 930, 3.52 Ghz GIGABYTE GA-X58A-UD3R CORSAIR XMS3 12GB 1600Mhz 2 X WD 1TB Caviar Black 64 GB cache MOTU Traveller PT2018 MacBook Pro Mojave 16GB DDR3 |
#35
Sent from my SM-G975U using Tapatalk |
#36
Lets hope
#37
I see those errors and PT being sluggish and laggy whenever I copy stuff over the network in the background.
I have scheduled backups running to my NAS over 10Gbe (has been the same with 1Gbe) every hour for the external SSD I mostly am working on. As soon as the file transfer to the NAS starts PT freaks out and is nearly unusable. It throws -9173 all the time, and there's input and GUI lag out the yin yang. When the transfer is finished all goes back to normal. Also in workspace there's a lot of APFS snapshots mounted, whenever this behaviour occurs. And when there's two drives with the same name connected (I had a backup drive for audio stuff named "audio" while also having an internal drive with that same name). Pro Tools doesn't like that at all. I guess they will need another decade at least until they arrive in the year 2020 with their programming staff.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
#38
Why do you think it is a good idea to do backups while working on a session? I would schedule daily when I sleep and computer/network can do the work. In other words, the day I think I cannot trust my storage to stay alive for 24 hours it is time to replace it.
#39
I don't care about limitations that derive from an inability to program a modern and stable software. If I want to do hourly backups of my WIP you can be sure I have a good reason for it. If you're not able to compute the reasoning behind that maybe you should apply for a spot amongst Avid's coding staff.
#40
I trust my storage, I don't trust Pro Tools. There was more than one instance where it crashed and took stuff with it. And autosaves didin't happen as instructed in settings. Pro Tools is a trainwreck, and I have too much work on my plate. I do not want to lose more than an hour of invested time and redo stuff. And I already have due to Pro Tools giving me the finger.
AAE error -9173 | nikydvt | Pro Tools 12 | 11 | 01-14-2017 04:05 PM |
AAE error -9173 on PT 12.4 | marcnyc | Pro Tools 12 | 2 | 06-24-2016 03:27 PM |
Error -9173 | music.m | Pro Tools 11 | 1 | 03-19-2015 09:42 AM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
