#141
Re: Input Monitoring Bug with Protools 10.3.9
I reverted back to 10.3.8 and it's working fine.
#142
Indeed, that's the only fix for this issue.
#143
I had the same problem (piss me off ) I reverted to the previous ver. And everything works. Thanks for pointing that out. Was going crazy trying to fig. Out why it all of a sudden dis not work. Funny thing is I think it works on my laptop with the latest version.
#144
#145
I'm experiencing the same Track Input Monitoring problems with 10.3.9 so I uninstalled 10.3.9 and installed 10.3.8. This did not work because Pro Tools refuses to start at all.
So I tried the manual uninstall procedure explained in earlier posts here and got 10.3.8 working again. But know the Hardware Setup Window is gone, when I click on it, no window will open. Did anyone had the same problem and has an easy fix or can point me in the right direction? EDIT: problem has been resolved. The only way was to restore an working partition with 10.3.8 from a bootable back-up HD. I tried a lot of other things, but nothing worked. So the actual reason of the disappearance of the Hardware Setup Window remains a mystery...
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins Last edited by Delta Music Belgium; 08-18-2014 at 01:31 AM. |
#146
Re: Track Input Monitoring 10.3.9 HD broken ?
same thing happen to me while trying to go back to previous version ( 10.3.8 ) so did i full unistall , jthen it worked for me
#147
#148
A fix in the works??? Anyone from Avid??? How long's it been now? Darn long time for sure.
#149
Is 10.3.9.462 the really last version?
Dick Maitland C.A.S. |
#150
10.3.7 working well here.
Just b/c the release version has a higher number doesn't mean it's a better release 10.3.7
Track Input monitoring!? | realizment | macOS | 9 | 11-04-2013 01:51 AM |
Monitoring input and track during playback | simonyeah | Post - Surround - Video | 5 | 09-24-2012 03:07 PM |
track input monitoring | vin7 | Pro Tools 10 | 6 | 08-28-2012 07:08 PM |
Pro Tools Track Input Monitoring??? | MLH Studios Inc. | Pro Tools 10 | 13 | 03-13-2012 11:03 PM |
Single track Input Monitoring?? | sylviesongs | macOS | 1 | 09-19-2011 01:41 PM |
