Re: Track/"Channel Strip" Presets DO exist in Pro Tools, apparently...
ohh geez, you're right..i didnt click on the wall.. i was signed in.... lol...
not a very frequent FBer am i!?
kickin' at the darkness 'till it bleeds daYlighT
Don't feel bad; this sometimes trips me up as well and I'm usually on FB a couple of times a day. Sometimes FB links change on their own and that makes for a real mess trying to follow something.
Ah. That makes some sense, as it would help beginners out, but every version should def have that feature. Especially if we could customize them.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
1) Go to Applications > Avid > Pro Tools. Here, create a folder titled "Track Presets". I also recommend creating folders within "Track Presets" for different categories (ex: Submix Masters, Reverbs, etc) although you can do that later on. 2) Create and configure tracks (including inputs, outputs, names, sends, volume, pan, plug-ins, etc) as desired. 3) From the File menu, choose Save As Template. 4) Choose "Select Location for template" 5) Navigate to your Track Presets folder (or sub-folders) or just save anywhere then move to these folders later. Once your templates are saved to this "Track Presets" folder (or folders within it), they will appear as options in the New Track dialog below the normal track types (audio track, aux input track, etc). You can still use Command + Down/Up to switch through these and Option Command Down/Up will switch between multiples in your sub-folders. Oh man! I so freaking stoked!!! |
#16
HD Native - Apogee Symphony I/O Mac Pro 6 core 3.33 Westmere 16 GB of RAM PTHD 10.2 OSX 10.7.5 |
#17
Yes, it does create a .ptxt file. However, you do have to make those subfolders inside of the Track Presets folder. The .ptxt files should then be saved/moved inside of those subfolders. Oh, another detail... Since "Save As Template" includes all tracks in the session, the session should only contain tracks that should be in the track preset prior to choosing "Save As Template". A different solution that might appeal more to your mentioned workflow is this:
-Select the track(s) in the large session that you want to use as a preset. -Choose "Export Selected Tracks as New Session" from the File menu. -Press OK in the resulting dialog. -Choose your location (inside of a subfolder within Track Presets). -In the Finder, change the extension of the session from .ptx to .ptxt. -Voila! |
#18
A huge round of applause to PTPhillip, great work!
Working here on 10.2 HD. This will be part of my workflow from now on. This should be in 10.3 officially, we just need a way of saving a strip preset directly without renaming for this too work. I know you can "import session data" - but what would be amazing is if when selecting an insert point on a channel , appearing under one's plugins and i/o there could be an option for "Track Preset" which would allow plugin import from a saved preset onto a prexisting channel. It should also be able to "downstream" i.e. if in slot one i have an eq I want to keep i could call the track preset up in slot two and that would be next in the chain. |
#19
I work with amazing people who do incredible things. Founder of the Expert Sites. |
#20
woooowwwwwwwwwwwww !!!!! Unbelievable that this isn't covered in the manual !!! This is a biiiiiiiig timesaver and imo a major new PT-feature! I will try it out immediately Thx so much
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Shortcut for "view channel strip" command? | Zakazastar | Tips & Tricks | 22 | 08-25-2014 10:13 AM |
"Channel strip presets / storage" in PT11 | yeloop | Pro Tools 11 | 2 | 07-25-2013 06:35 PM |
"Fatal exception has occurred. Pro Tools must exist" | Mattlewis | Windows | 3 | 07-25-2013 10:48 AM |
Problem "apparently" finally solved; No more mouse freeze! | dkrausz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-15-2002 08:00 PM |
No "Channel Strip" For PC | B.Ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-30-2001 10:38 AM |
