Pro Tools 10 Error - DAE can't get audio from the drive fast enough
After recording or playing my session for about 30-50 seconds I'll get this message:
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or a firewire drive could be having trouble due to extra firewire bandwith or CPU upload" I used to run everything off my computer's drive, as opposed to an external drive, but then Pro Tools started to lag (for both playback and recording). I then realized I should probably be using an external drive. That's what I'm doing right now, and the lag has stopped but my sessions keep getting interrupted by this error message so I can't record a full song. If you need more details from me, let me know, but I'd really appreciate the help right now. I'm desperate to record my music, and this is killing me. |
Re: Pro Tools 10 Error - DAE can't get audio from the drive fast enough
Help us Help You - READ THIS Before Posting!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
A few things...
1. Are you using an external drive for your PT sessions and audio files? Meanning not using your OS drive and If so is it a 7200 RPM drive? Is it firewire? USB? 2. What is your playback buffer set to (Have you tried increasing this to 1024?), how many cores are you using (or how many is selected in that window)? Go up to SETUP>Playback Engine You arent using PT HD software so you cant use disk cache to speed up loading the data into RAM so your options are to fine tune your system and Pro Tools to get the best results. |
defrag your drive see if that helps.i got that message too but i defraged the drive and it started working again
SANDRA report will let us know...
Who's taking bets? Bet he's trying to record to the system drive.
Incidentally, if there's already PT sessions on the drive, defragging it will make a mess of everything. |
I'm not recording to my system drive. I said that in my OP.
I WAS recording to a 750GB external drive. Now I'm using a 16GB USB and I haven't gotten that error message so I'm pretty sure it's the external drive that's [bleep][bleep][bleep][bleep]ed up. I did try defragging it, but it didn't work. Also, what's a SANDRA? |
Oh and thanks for all the replies, I can't believe how helpful this community is. I really appreciate it.
DAE can't get audio from the drive(s) fast enough (-9073 error) | DeDemoman | macOS | 9 | 04-26-2015 04:13 PM |
DAE error -9073 DAE can't get audio from the drives fast enough. Your drive may be to | drewmack76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 03-22-2012 06:39 PM |
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or | iminzayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 04-15-2010 10:28 PM |
Error -9073 DAE Can't get audio from drive fast... | stayce9665 | Pro Tools TDM Systems (Mac) | 24 | 12-08-2009 11:43 AM |
Error Can't Access Hard Drive Fast Enough | johnallen31 | Pro Tools M-Powered (Win) | 5 | 04-10-2009 07:36 PM |
