Signal generator TDM out of phase....
I was just aligning up our pro tools system.
For test i made a stereo audio track and put the signal generator on, making a 1kHz sine @ -18 dBFS. I then discovered that it's a little bit out of phase, which it shouldn't be at all! I have doublechecked that delay compensation is not on (which can make phase issues sometimes....) I have also put it on a mono track, and here everythng is ok. The funny side of this, is that if i use an rtas version of the signal generator on the stereo it's completely in face! The phase is checked on the phasescope plugin, and on an external phasemeter. Anyone who has the same issue ? the system is a HD2 v. 7.4cs5 running on OS X 10.4.9 |
Re: Signal generator TDM out of phase....
Also changing the frequency and the phase changes drastically! and when i kept changing from rtas to tdm each time i went back to tdm the phase would be slightly different. Chris
What do you mean by out of phase in this context? Out of phase with what?
JGuth:
The mono sinus is on a stereo channel, going to out of pro tools on 1-2. In this way they shouldn't be any phase issues on the phasemeter = +1 But it's almost in 0 on the phasemeter which under no circumstances should happen.... |
Chris
I've seen this before - it seems to have been this way for a long time - going back to at least 6, maybe even 5..
I have always found it necessary to bus a mono SG to two aux returns. David |
Signal Generator is a Multi-Mono plug meaning that each channel is a separate instance
Now if there beating with each other thats a problem
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
confirmed here, RTAS and Audiosuite fine, TDM not
Chris
YES this has been a problem for some time. I've pointed it out in the past but it has never changed. Also of note the pink noise is worthless, worthless, worthless!!!
Multi-mono Signal Generator TDM out of phase !!! | mangoustine | Pro Tools TDM Systems (Mac) | 5 | 04-15-2019 04:53 AM |
Bug in 7.2 Signal Generator | Craig F | Pro Tools TDM Systems (Mac) | 1 | 10-12-2006 03:17 PM |
Signal generator out of phase | garret | Pro Tools TDM Systems (Mac) | 12 | 12-01-2005 10:19 AM |
Signal Generator | Punx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-09-2002 05:56 AM |
signal generator for what use? | jinsel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-11-2002 03:01 PM |
