Old 05-29-2007, 02:48 AM
Jimmix Jimmix is offline
Default monitor board out / repair
Hello
My entire monitor section went out. I have checked everything and reset everything. The only thing I have not done is opened it up and looked for loose connectors.
my question is this
1- could this be a power supply issue. it has an original power supply and is one of the first c24 series.
2- the left side of my aux monitor (musician cue) went out. is that on the same board as the main monitor section?
How much do these boards cost from tech support?
I assume I need ether a power supply and a monitor board or just a monitor board.
Any and all help is most appreciated
thank you
jim
Old 05-30-2007, 01:26 AM
uisdean uisdean is offline
Default Re: monitor board out / repair
It could the power supply. Have your faders stopped working? if so then it's more than likely the PSU, check the internal PSU fuses to see if they're blown, also check your mic pre's as they can also be affected. It's a bit of a fiddle to remove the PSU. Digi used to supply the PSU's free of charge, give tech support a call to see. I'm assuming that all your monitoring, alt and main etc have stopped working. Hope this helps
Profile as a monitor Board wolvesandi VENUE Live Sound Systems 7 01-08-2011 05:15 PM
Hum and DC from center monitor. Anyone know if it's the PS or Monitor board? Gordon Hookailo ICON & C|24 2 12-18-2010 01:42 AM
Mixing board repair Ryan Young General Discussion 4 02-04-2007 04:34 PM
Pro control monitor board upgrades.... NCM engineering ProControl, Control|24, Command|8 12 06-15-2001 02:57 PM
Monitor Board "Upgrade" bairtracks ProControl, Control|24, Command|8 30 04-01-2001 03:35 PM
