Pro Tools 9.0.5 Update Problems
I've downloaded the PT 9.0.5 update. But when I try to install it I get this error message, "This Updater cannot locate a valid Pro Tools installation on your system." I'm running my registered PT 9.0.3. So I re-downloaded the update and am still getting the same message. I'm running OS X 10.6.8 on a MacBook Pro. Can anybody help me?
Re: Pro Tools 9.0.5 Update Problems
Have you moved the "Pro Tools.app" file to a different location? Have you renamed the file for some reason? It may have to reside in the original install location and have the original filename for the updater to find it.
"Applications > Digidesign > Pro Tools > Pro Tools.app" Just a thought TB
27" iMac 3.2 GHz Intel Core i5 ... 24GB RAM ... OS 10.10.5 ... Pro Tools 9.0.6 ... Mackie MCU Pro ... Zoom R16 (x 2) ------------------------------------------------------------------------------------------------------------------------------- My plan is to live forever . . . so far so good |
Re: Pro Tools 9.0.5 Update Problems -- 9.0.6 too
9.0.6 update -- same issue for me.
I downloaded and ran the installed. It prompted me to quit all running apps (including PT) which I did. It then spent about 10 minutes installing and "optimizing", then gave a very vague error message about not being able to complete the installation, suggested that I try again, and quit. When I try again as suggested, it tells me "This Updater cannot locate a valid Pro Tools installation on your system. Press "Close" to continue." And sure enough, it ate my Pro Tools app. Suggestions? |
Check this out:
http://duc.avid.com/showthread.php?t=312832 In my case, not only did I have to go back to 9.0.3 (from 9.0.5) but, in order to do so, I had to use another OS installed on another drive (PT 9.0.2, which you have to reinstall to start from scratch, wouldn't install although I had performed a full desinstall of PT)... So convenient... Now it's 9.0.3 until I go PT10 (=not before a while).
Pro Website Administrator of Brotools, free online tutorials for the french Pro Tools user. |
Re: Pro Tools 9.0.5 Update Problems -- SOLVED!
SUCCESS! And this is kinda funny because of how darn simple it was.
Last time this happened to me with a previous point release update, I made the mistake of contacting tech support who had me clean reinstall my OS for frack's sake, and jump through all the annoying and time-consuming PACE copy protection crapola hoops. This time I tried something silly: I launched Time Machine and restored my app to its previous position in the Applications > Digidesign > Pro Tools folder. Ran the installer again (same installer, didn't re-download or anything) and this time it worked. Just launched PT and everything seems to be hunky--About says 9.0.6 and everything. Heck, I just saved myself a day of IT PITA. Thank god for Apple and backups. And yes, I blame PACE. But then I blame PACE any time anything goes wrong. Note that this is the app-eating installer error, NOT the checksum download error from the other thread SD2 referenced. http://duc.avid.com/showthread.php?t=312832 (And my sympathies, SD2--sorry my solution probably won't help. I feel your pain!) |
But, in the link I provided, I think I remember we also talked about that disappearing app problem. Thus the link.
pro tools 10.2 - 10.3 update problems!!!! | twilite | Pro Tools 10 | 0 | 09-24-2012 09:32 AM |
Pro Tools HDX OSX 10.7.3 update problems | ighmaui | Pro Tools HDX & HD Native Systems (Mac) | 3 | 02-03-2012 04:00 PM |
PT 8.03 update problems! | kevor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-31-2009 06:47 AM |
update and PT problems | Empireofthesun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-17-2008 02:37 PM |
problems since 6.4 update *STILL | charles_Mundelein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-28-2004 04:56 PM |
