#121
Re: Transition to AAX: A Real Programmer's Perspective
DPM files are still stored in their old location. Pro Tools will load from both directories and apply appropriate plug-in dominance rules to figure out which one shows up in the menus... Very much thought through dominance rules... Dave |
#122
Dave |
#123
Dave |
#124
VST doesn't have the ability to build the processing part of the algorithm to live on embedded DSPs. VST3 is pretty nice actually, and I wouldn't trash it for a native only plug-in spec, but we make more than just Pro Tools. And obviously more than just native engines, even within Pro Tools. To accomplish this aspect of AAX, we had to strictly separate the processing code from the data/GUI and set up a communication layer that would work, not only across processes, but across processor architectures. I would assert that this is not feasible with VST. We also separated our GUI from our data model (parameters and stuff) in AAX differently from VST and AU for more future looking reasons. The bottom line is that we're trying to build an architecture that meets our pressing needs today (HDX, 64 bit), but also is architected for some future products. It's easy to talk about the requirements for HDX and 64 bit, not so much the future stuff, so I'll leave it at that. Does that answer your question? I'd be happy to dig into more specifics if necessary. Dave |
#125
And just to be clear, AAX plug-ins are not backwards compatible. They will load on PT10 and later, but they won't load on PT9. We looked at doing that at one point (for AAX Native), but it was going to be a significant amount of work and likely cause a bunch of bugs, which is the last thing our customers need... We were able to keep RTAS and TDM compatible with PT10. Forwards compatible? Kind of a pain actually, but an absolute requirement for all of you guys. Dave |
#126
Old PT code took advantage of SSE, Any chance AAX will take advantage of AVX?
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#127
Dave |
#128
Thanks for the info and @ DaveTremblay Thanks for your confirmation I was really hoping you or someone from Avid would answer. so Thanks I would still hope you could confirm the Windows file path. Don |
#129
If I create a session in PT10 and save it in the PT9 format, with aax plugin like 1 band EQ, will the PT9 session be able to know that I changed the settings on the EQ and recall them in the rtas version of the same plugin? That's really what I was trying to say, compatibility of plugin settings.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
#130
Dave |
A Programmer's Perspective on the AAX Transition + Q&A | reichman | AAX Plug-ins | 32 | 07-16-2012 02:25 PM |
perspective control 24 | youbringmesuffering | ICON & C|24 | 10 | 01-31-2010 09:27 AM |
PC to Mac....looking for a little perspective | Studio66 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 10-09-2008 03:50 PM |
Reason / PTLE (different perspective) | basis3708 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 09-06-2001 07:58 AM |
Female perspective | Doc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-16-2001 09:21 AM |
