Sample Rate Not Changing With Session
I don't normally flip back and forth between 44.1 and 48k, but I'm doing several mixes right now at different rates, and I'm noticing that my HD rig isn't changing when I open each session. This means the music plays back either slow or fast, depending on where I am. I have NEVER seen this before. I'm not using any external sync boxes, and nothing in my rig has changed in many moons. This is with 8.0.3cs2.
Has anyone else noticed this? The only cure is to shut down PT. Thanks, Sig |
Re: Sample Rate Not Changing With Session
I have never seen that. You say you are on 'Internal Sync' under the setup? You don't for instance have channels 1 and 2 set to optical input and the sync set to digital? That's about the only thing I could figure.
If not, then it does sound like you've got something messed up, did you try trashing all your preferences, DAE, DigiSetup files, and reboot? That one sounds weird. |
Changing Session Sample Rate ? | 25ghosts | Pro Tools TDM Systems (Mac) | 3 | 06-09-2007 05:42 PM |
Changing entire session sample rate.. | lunybird | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-14-2007 01:54 PM |
Changing LE session from 48 to 44.1 sample rate | ansanity | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-12-2006 11:11 PM |
Changing the sample rate of an existing session | Torgo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-12-2004 08:52 PM |
Changing Sample Rate On An Exisiting PT Session??? | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-01-2004 11:00 AM |
