Old 01-03-2020, 03:40 PM
Ben Jenssen's Avatar
Default Re: Focusrite 18i8, iMac High Sierra, Midi keyboard
Originally Posted by Southsidemusic View Post
Ok then PT should find that keyboard if connected correct and setup correctly in PT and the Mac. No drivers or HUI or anything like that.
Which is what i said.
Old 01-04-2020, 09:31 AM
mophilly mophilly is offline
Thanks to all who have posted. I really appreciate the suggestions and info.
For the record, here is the current details from my PT project.
-- Hardware and Software
Pro Tools 2019-12
iMac (late 2013) running MacOS Catalina (10.15.2)
Yamaha P-105
Focusrite Scarlett 18i8 2nd Gen
-- Pro Tools Setup
Hardware: Scarlett
Playback Engine: Scarlett, HW Buffer size 256 Samples, playback cache 1GB
Peripherals: installation defaults
I/O: default paths to Scarlett; all other settings default on installation
MIDI setup:
MIDI Studio: Scarlett and a general device that I named as piano. Manufacturer is Yamaha, nothing in model
MIDI Beat Clock: “Scarlett” enabled, “Expand!2 1” disabled
MIDI Fitler: defaults
MIDI Input Devices: Only Scarlett listed and it is selected
-- Track: 1 (works)
Input: Input 1 of Scarlett, connected to Shure microphone
Output: BO12 (Scarlett analogue 1)
Instrument: nothing
Inserts: AIR non-linear reverb
Sends: none
-- Track: 2 (not working)
Input: no input… what goes here? input, bus or plugin? plug in is greyed out.
Instrument: All, none
Insert: multi-channel input > EQ > AIR EQ Kill
Send: none
Old 01-04-2020, 01:23 PM
Doesn’t the Focusrite Interface have midi in and out? If so just get 2 cheap 5 dollar midi cables and connect to the keyboard and if it doesn’t have midi in and out and you dont have USB Midi on the yamaha you need 2 cheap 5 dollar midi cables.
Does it look like this on the back?
Yes, the back of the Focusrite Scarlett does have the 5 pin DIN connectors for midi in and out.
However, the Yamaha P-105 has a USB type B connector. https://www.cablestogo.com/learning/...es/usb#!b-type
The cable I have is USB type B to USB type A, similar to this: https://www.bhphotovideo.com/c/produ..._0_Type_A.html
I have looked around for a USB to MIDI 5 pin DIN adapter without any luck.
The Yamaha P-105 does have auxiliary output, but that would not be MIDI.
Old 01-04-2020, 01:45 PM
And that's all you need. Plug it in the computer and get going.
Old 01-04-2020, 03:21 PM
Yeah! Except it doesn't. I cannot "see" the piano in the PT input.
Old 01-04-2020, 03:29 PM
Like I said earlier; unless something is faulty, it should be automatically recognized by PT. Plug it in (the keyboard), restart pro tools, make a instrument track, insert a instrument plugin on it (to make the sound when you hit the keys), and make shure the instrument track is selected (its name is highlighted), and it should work.
Old 01-04-2020, 03:52 PM
Thank you, Ben. I will try again.
Old 01-04-2020, 03:54 PM
I'm sorry, I should have pointed out; the piano will not show up in track input selectors. It's a midi controller, and the clue is to select the midi- or instrument track you want it to control.
I hope you're aware that as a midi device, it won't output its own sounds, it will only be a way to trigger instrument plugins.
Old 01-04-2020, 04:06 PM
So, if you want to use the piano as a sound source, just connect its stereo outputs, L&R, to your interface, make a stereo audio track with input set to 1-2, and rec enable it.
Old 01-05-2020, 07:37 PM
Thank you, Ben, for taking time to help me through this.
You wrote, "It's a midi controller, and the clue is to select the midi- or instrument track you want it to control." Hm... somewhere along the line I got the impression that the digital piano was not a midi controller. I will work along that idea and set up a new track.
iMac 2017 / High Sierra / ProTools 12.8.3 ... the worst combination ?? cozy_man macOS 11 09-17-2019 01:24 PM
No MIDI thru in 2019.5 and High Sierra Ray Lyon MIDI 0 06-07-2019 09:19 PM
Digidesign MIDI IO with PT 2018 / High Sierra? Zep Dude MIDI 1 02-04-2019 07:57 PM
Mbox Mini (3rd gen) not connecting in High Sierra on old Mac Mini or new iMac Hoevelmann FireWire and USB Audio Interfaces (Mac) 0 04-26-2018 10:49 AM
Focusrite Scarlett 18i8 - High pitched, faster recorded issues Stef1342 Pro Tools 12 15 07-31-2017 01:53 PM
