Old 07-23-2001, 09:36 PM
eric-shi eric-shi is offline
Default Touble like autotone
i'v met the same question with autotone and c24, maybe updating to the version 3 can solve the problem, but i have a lot of other third-partner plugins, and there's the same problem. is there any solution i can find except for disabling the c24? it's quite boring. and is this problem going to occur when using Pro Control? [img]images/icons/frown.gif[/img]
Old 07-23-2001, 10:23 PM
Default Re: Touble like autotone
and is there anybody can provide me with the autotune3 's download link?
Old 07-24-2001, 09:14 AM
ashdot ashdot is offline
Autotune 2.xx is the only problematic plugin we've met so far.
Which other plugs did you find incompatible with C24?
Izhar
Old 07-26-2001, 10:14 AM
budy budy is offline
the waves 3.0 gold Bundl.
You can not access the parameters very comfortable because all parameters on the EQ´s show "band" [img]images/icons/confused.gif[/img] on the C24 led´s.
maybe fixed in 3.2?
Guitars Recording Touble mike42 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-27-2006 02:49 PM
