Old 01-04-2014, 07:30 AM
enricocremonesi enricocremonesi is offline
Default Issues installing ProTools 10 on external SSD
Hi,I am trying to install Pro Tools 10 on an external SSD (Samsung EVO 500 Gb)
This SSD is formatted in Extended Mac OS Jouornaled and I installed on it also Mountain Lion (I am starting my macbook pro 17 using mountain lion on that ssd)
The Pro Tools 10.3.8 Installer tells me that there is an error installing...
Is there something I am doing wrong or any known issue?
Thank u very much 4 your help.
Kind regards
Enrico
Old 01-08-2014, 12:19 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Issues installing ProTools 10 on external SSD
Kind regards
Enrico
Maybe I'm mistaken or this isn't the issue - but shouldn't Pro Tools be installed on the computer's system drive? I didn't think you could use Pro Tools when installed on an external drive.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-08-2014, 12:31 PM
What *exact* error did the installer give?
What exact OS X version is installed on that external drive.
If you have an external drive with OS X on it and you are booted from that drive you should have *no* problems installing Pro Tools software on that drive as well (I do it often).
However you need to only install Pro Tools while actually booted from that drive and you also need to make sure that both drives do not have the same name. Make sure you really are booted from the drive you think you are.
Are you following the install instruction in the Pro Tools install documentation?
Issues installing protools LE 8 on Windows XP SP2 dannyt18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-27-2011 01:17 PM
Re-Installing Protools on a New External. freezegelman General Discussion 5 08-21-2007 11:44 AM
Installing protools to external hard drive Lonald 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-16-2007 12:03 PM
Issues after installing UAD-1 Concious Burning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-05-2005 12:17 PM
Installing ProTools MBox on an external harddrive? jensen5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-17-2005 12:30 PM
