Old 05-03-2014, 03:29 PM
Farmer Dave Farmer Dave is offline
Default PT 11.1.3 - Bizarre plug-in behavior
10.8.5
11.1.3.325
10.3.8.378
2.66 Ghz Quad-Core Intel Xeon
16GB RAM - 1066 MHz DDR3
Eucon 3.1.2
Artist Mix
Artist Transport
Audio Hardware - Coreaudio Aggregate MOTU HD Express & 828mk3 Hybrid
ATI Radeon HD 4870:
NVIDIA GeForce GT 120:
I've been seeing this in previous versions of PT11 too, so not new.
The main plug-in I notice this on is DMG Equick.
1) I have a multi-mono instance of EQuick (1.07) on a 7.1 Aux.
2) Automation on this aux is OFF.
3) The setting I have for EQuick recalls with the session, but the moment I press PLAY, EQuick sets to a completely random setting. It will then stay there - ie - doesn't change the next time I press play.
Old 05-04-2014, 12:01 PM
Default Re: PT 11.1.3 - Bizarre plug-in behavior
I can verify the exact same thing happens with Fabfilter Pro Q.
The session opens up and the plugins are set as I saved them. But as soon as I press play, a random setting occurs in both EQuick and Fabfilter Pro Q.
Old 05-04-2014, 12:23 PM
DetroitT's Avatar
DetroitT DetroitT is offline
EQ7 try as it sound like a plug-in issue, clear the AAE pref to rescan plug-ins.
(Help us Help You)<<<click here
APFS 90% 10% Audio on Both
(HFS+)
Pro Tools U-2019.12 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MVC-Edition)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDIoverIP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
new systems builds/upkeep
Old 05-04-2014, 03:48 PM
EQ3 behaves fine
Confirmed now to occur in at least 3 different 3rd party plugins:
EQuick
Fabfilter Pro Q
Alloy 2
It looks like failure on multi-mono plugin instances, even on stereo tracks. The plug-in "usually" recalls the settings upon session opening, but will set to a random setting once transport is engaged, even though the track is set to automation OFF.
This does NOT occur if the session is opened in PT10.3.8
Here is a copy of a fresh session that shows this behavior, with:
mono - WORKS FINE
stereo (with Stereo plug-in instance) - WORKS FINE
stereo (with multi-mono instance) - FAILS
LCR (with multi-mono instance) - FAILS
5.1 (with multi-mono instance) - FAILS
https://dl.dropboxusercontent.com/u/...all%20test.zip
And here is a screen capture of this occurring. The 2 instances of the plugin on the left are not multi-mono. The 3 on the right are multi-mono and ALL three show this behavior.
https://dl.dropboxusercontent.com/u/...callError2.mp4
As stated, EQ3 does not show this behavior, but multiple 3rd party vendor plugins do. I've been seeing this in all versions of PT11, but it doesn't happen in PT10.
Old 05-04-2014, 04:39 PM
Add McDSP ML1 (again Multi-mono) to the list.
This is really problematic, and is one of the reasons I keep having to postpone the switch to PT11. For those of us in Post, multi-mono plugins are a must dealing with tracks that are LCR and up in track count.
Old 05-04-2014, 05:19 PM
This ALSO occurs after an offline bounce, with the multi-mono plugins generating a random setting.
I'm going to have to go back to 10.3.8. I can't risk this any more.
Old 05-04-2014, 06:23 PM
TimNielsen TimNielsen is offline
Confirmed that if I take Dave's session to a Mavericks machine, 10.9.2 and pt 11.1.3, can reproduce every time. Simply opening that session and hitting play, the settings randomly change, and don't change the same way each time.
Seriously dangerous bug.
Old 05-04-2014, 06:50 PM
philip888's Avatar
philip888 philip888 is offline
Ok sorry for you guys.
Glad I am holding off.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.4 Antelope Orion 32
Old 05-04-2014, 09:25 PM
Danny Caccavo Danny Caccavo is offline
I have regressed it, written it up and reported it to Avid
FWIW, I'm finding this problem with Brainworx BX Digital V2 in all versions of PT11. With MDW I could only reproduce it in 11.1.3.
Old 05-04-2014, 09:41 PM
Thank you Danny!
Edit window - right/left arrow keys - bizarre behavior Londoner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-05-2010 06:47 AM
Akai MPD26 creating some really bizarre PT click behavior Jonny Jon Jon MIDI 0 05-07-2010 01:48 PM
PTHD for Windows -- bizarre Edit Window behavior jjnyc Pro Tools TDM Systems (Win) 4 12-09-2007 07:53 PM
Bizarre behavior on D-Control Mikey MTC ICON & C|24 2 02-12-2007 11:09 PM
Bizarre Premiere 4.2 Behavior JKD99 Post - Surround - Video 8 02-20-2004 10:27 AM
