Old 12-06-2013, 03:44 PM
cvanscott cvanscott is offline
Default OS Compatibility
I am building a new machine to run PT 8 LE. I was under the impression that I was limited to 32 bit Operating Systems. I see now that PT 8 LE is listed as being compatible with Win 7 64 bit. If this is the case, I may upgrade to that instead of using 32 bit XP as I had intended. Can anyone verify this, or are there known issues with 64 bit Windows 7 running LE? thank you.
Old 12-06-2013, 06:09 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: OS Compatibility
From memory, I think v8.04 upwards is supported on Win7.
If you have a version before 8.04 you'll need to install the update (not to be confused with upgrade) which is free.
Upgrades are not free.
Just to clarify; Some updates are 'Full Installers' and others need a full installation before running the updater. The downloads are labelled to identify whether or not they are a full installer.
If you run a full installer you must un-install any previous version of PT before running the new installation.
On the other hand, if the updater is not a full installer do not un-install previous version. Just run the updater as a 'patch'.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 12:05 PM
V9 Compatibility GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-16-2010 05:51 PM
Mac OSX Compatibility Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-24-2007 10:33 AM
UAD-1 and PT7 Compatibility M15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-09-2005 12:19 AM
PCI-X Compatibility kcurry Pro Tools TDM Systems (Mac) 6 07-14-2003 06:45 AM
