Old 10-26-2011, 08:08 AM
Rockman413 Rockman413 is offline
Default Have you met this occasion? Help!
Everything works great but today, when I have 4 stereo tracks ARM and my transport is in Quickpunch mode, , after I hit spacebar, it takes about 5 seconds to play....Actually When I only one stereo tracks ARm it still costs 1 seconds to playback.
But without track on ARM or Quickpunch, pro tools HD playback immediatly...
I save my session another disk, it does better, but still some siginificant delay when I hit spacebar.
I checked my system and my Mac's audio output are set to internal speakers.
Help!
Old 10-26-2011, 08:15 AM
midnightrambler midnightrambler is offline
Default Re: Have you met this occasion? Help!
1. Check your hard drive isn't nearly full (or over 90% capacity)
2. Go to preferences->operation->"open-ended record allocation" and set the limit to something relatively low (I have mine set permanently on maximum of 10 minutes)
Old 10-27-2011, 02:24 AM
jeremyroberts jeremyroberts is offline
Turn off midi pre-roll.
Numeric keypad: 8
--Jeremy
Old 10-27-2011, 03:58 AM
umalight umalight is offline
Yes, I had that when my Time Machine HD was defective. It took me some time before I found out. Have you tried to deactivate time machine ? It might also be you hard drive slowly dying . Backup everything ! :)
Old 10-27-2011, 05:26 AM
This solved my problem. . Thanks!to all of you.
Record allocation means what?
Old 10-27-2011, 06:31 AM
Fairly good explanation here (about halfway down) - :http://www.soundonsound.com/sos/mar0...kshop_0307.htm
How should I Delay Compensate for this occasion with Vienna E Pro? Rockman413 Pro Tools 10 3 10-05-2013 12:53 AM
