Old 06-06-2011, 03:03 AM
alex weber alex weber is offline
Default WAV timecode / time stamp question
To audio post people...A video editor included an audio clip in my edit window that needs to be fixed but I can only fix it if I go back to the original session the clip was from. So how do I see the original timestamp
key-replacement
from the original session of the region I'm trying to fix so I can go back to that session and fix the clip? If only I had original time code of the clip that'd help me out hugely. Right clicking on the region doesn't give me any useful info, when I click on the timestamp it shows user timestamp of 5 seconds. I suppose this is another question but when you import an OMF file into your .ptf session does protools automatically timestamp all regions to their current locations? If I highlight all my regions in my regions list and click on "timestamp" and timestamp all those regions will it add timecode to all those clips based upon their locations in the edit window?
Old 06-06-2011, 03:09 AM
Default Re: WAV timecode / time stamp question
If you use an embedded OMF all the original stamps are stripped i.e. stamped at their current location. Ask for a referenced OMF to maintain the original meta-data.
If it´s only one single clip also a simple BWAV export will do instead of an OMF.
PTHDn 2019.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
HTML code is On
Spot to Original time stamp question oscarwonderboy Pro Tools 10 3 04-20-2013 05:17 AM
Region Time Stamp Question Schrider Post - Surround - Video 13 03-06-2012 08:30 AM
WAV timecode / time stamp question Nathan W. Post - Surround - Video 8 08-30-2010 06:11 PM
time-stamp all regions to their current timecode komokrator Post - Surround - Video 0 12-18-2007 05:01 AM
Exporting files with timecode stamp daniel_c Tips & Tricks 1 01-13-2001 03:34 AM
