Old 05-07-2010, 03:34 PM
AlexTodorov AlexTodorov is offline
Default 2GB RAM limit for Virtual Soft Instruments/PT 8? ?
I'm working on the score of a major feature movie in the moment and I have to work with soft instruments that load a lot os samples in the memory.
Seems that every time I go over 2GB of RAM used for Pro Tools my MacPro with 8Gb of RAM it starts to crash. ( I can see how much RAM memory is used by each application in Activity Monitor. It says that I still have 4GB free). I did try to fine tune my system, but nothing helps.
Could that be a poor Pro Tools RAM management, or I do something wrong?
I have all the newest versions of Plug Ins - most of the time I use Play and NI Komplete 6.
Does somebody else have the same problem?
Alex Todorov
Old 05-07-2010, 03:59 PM
DrFord's Avatar
DrFord DrFord is offline
Default Re: 2GB RAM limit for Virtual Soft Instruments/PT 8? ?
As I understood Pro Tools caps at 4 gig...
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 05-07-2010, 04:56 PM
joji joji is offline
what up with that. that is not cool logic and others can do way more and cost 90% less and are just as good
Old 05-07-2010, 06:12 PM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Well PT is really only at about a 2002 level regarding VIs. I bet they'll catch up to Logic 2010 by 2015 or so.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 05-07-2010, 06:27 PM
TimNielsen TimNielsen is offline
It's not really ProTools fault, they didn't 'cap' anything, it's just that 32 bit applications, which ProTools still is (it will be a long while we suspect until we see a 64 bit ProTools) can only access 4 gigs of ram. This is a limit for any 32 bit app.
But some plugins can cleverly get around this, and actually, Kontakt 4.1 which just came out in public beta, is a 64 bit plugin, and Play 2.0 was just released a day or so ago, not sure about it. I'm not sure if these will operate as 64 within ProTools, or only as stand-alone.
BUT, your issue sure sounds to me like bad ram. If you're able to use up to 2 gigs but crash over it, I would highly suspect you have a bad ram chip that isn't getting accessed until PT crosses that 2 gig limit, at which point you're crashing.
Although, I just posted a thread where I was seeing something very similar, I was running Play and Kontakt, and ProTools was crashing with a 'critical memory' error, saying I was out of ram. I have 10 gigs in my machine, and ProTools wasn't using even 2 gigs I don't think.
Digi said they thought it was possibly incompatible plugins, but they say that about everything that every goes wrong on a ProTools rig :)
But it could be that too. Try the newest Kontakt 4.1 public beta, and update to Play 2.0 though, as they both just released.
Tim
Old 05-07-2010, 06:32 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
I don't think we'll see that @ all TBO...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 05-07-2010, 06:44 PM
burningbusch burningbusch is offline
Kontakt 3.5 and 4.0 have a Memory Server capability which allows it to use memory above 4GB to load samples (up to 32GB). This works with 32-bit DAWs and 32-bit OSs. Spectrasonics Omnisphere and Trillium have a similar capability.
Busch.
Old 05-07-2010, 06:50 PM
Busch I'm not sure how that would work with a 32bit OS when the cap period is 4gig or in the case of PC, unless W7, is less than the full 4...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 05-07-2010, 07:41 PM
I'm not sure either, but supposedly it can be done, and doesn't require a 64 bit OS. I'm sure it's some cleverness, but they claim it can be done.
As for 64 bit PT, yeah, probably never is right.
Old 05-08-2010, 12:33 AM
JohnO JohnO is offline
Get Play 2, just out. The 'memory server' in Play (called ousiad) is 64-bit and can supposedly access whatever RAM you have. EW says to launch Play before Kontakt as the Kontakt memory server grabs all available RAM.
And all you Logic lovers, I'm guessing you don't have it or use it. HUGE memory problems with Logic 9.1 Hear the latest Logic user's love:
http://www.gearslutz.com/board/music...g-exposed.html
johnomix.com
192 Soft Limit gonzolagonda Pro Tools TDM Systems (Mac) 7 03-22-2007 02:48 AM
To Soft-Limit or Not to Soft-Limit? Bambison Pro Tools TDM Systems (Mac) 17 03-27-2004 02:53 AM
PLEASE HELP!!! 32 track limit on soft or hardware? mithranda2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-25-2003 04:55 PM
Re: 192 Can I enable soft limit via software? everglass Pro Tools TDM Systems (Mac) 2 03-25-2002 06:31 AM
UV 22 - Soft Limit Sergent Pepper Tips & Tricks 12 06-09-2000 05:16 AM
