Old 04-06-2005, 05:52 PM
rabbitears rabbitears is offline
Default why can\'t I play with the playback?
Hey Protools masters-
I do a lot of dubbing and want to audition my instruments through the Digi 002 while playback is running on the outputs. Isn't there a way to do this? It seems to disable the input monitoring when playback is started! so up until now, i have just been recording to hear both at once, and then Undo-ing the record until I figure out what I really want to lay down. An alternative to this method would be v. cool.
One more question; what happened to my gridlines in grid mode? They up and just disappeared one day. Thanks y'all.
K
Old 04-06-2005, 06:22 PM
Ben Jenssen's Avatar
Default Re: why can\'t I play with the playback?
1. Operations menu - "Input only monitoring"
2. "Draw grids in edit window" in prefs might have been deselected.
>does not play 48mhz with playback Thywingedfallen Pro Tools 11 5 12-27-2013 06:26 PM
Can't play keyboard during playback rjv0807 Pro Tools 10 1 12-20-2011 10:47 PM
003 play button & midi playback pbb@wn.com.au 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2007 08:05 PM
I cant play along during playback sainsomnia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-05-2006 06:10 PM
Transport Play Lit, but no playback slimfass27 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-17-2005 05:57 PM
