Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 02-28-2014, 08:39 PM
Shan's Avatar
Shan Shan is offline
Default Re: ...add more inputs to OMNI
Originally Posted by 68Tele View Post
So does connecting a 192 I/O or an Avid I/O to the expansion port of the OMNI give you more than 8 simultaneous inputs for recording?
OR...
Is the OMNI strictly limited to 8 inputs at one time no matter what?
You'll need to add the 192 to the I/O port of the HD Native card to expand your I/O.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 03-01-2014, 08:13 AM
nst7 nst7 is offline
You can have up to 64 in and 64 out on an HD Native card (or Thunderbolt unit). This can be done by using various HD interfaces like the HD IO (16x16, 8x8, or digital), or the older blue interfaces like the 192 or 96io. Or you can use 3rd party interfaces that hook up to HD cards, such as some of the Apogee units.
Old 03-01-2014, 12:30 PM
Mike496's Avatar
Mike496 Mike496 is offline
I use an Omni with HDN/HDX with a digi 192, works very well.
Old 03-06-2014, 07:59 AM
mandal mandal is offline
Shane
...using the second port on the PCIe card?
Can you recommend a tried & tested Apogee box ?
Thanks
Win10 Home (64-bit), Avid OMNI PCIe, Pro Tools Ultimate 2019.12, Avid HEAT, i7 processor, 16GB RAM, Samsung SSD 840 EVO (system disk), Siemens SSD840 PRO (session disk), Dell 43" 4K LED P4317Q
Old 03-06-2014, 01:46 PM
Tim R. Tim R. is offline
Thanks
I've got a Rosettta 800 (with X-HD card) running with my OMNI that works flawlessly (HDN Thunderbolt).
Tim Reisig
System 1: Pro Tools Ultimate 2019.12.0, HD Native TB, HD OMNI, S3/Artist Transport/Eucon, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Old 03-09-2014, 08:03 PM
This is the Windows section and Apogee does not support Windows. some may not be fully aware of this.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
Old 03-09-2014, 08:25 PM
For what he's talking about, it doesn't matter if you're on Windows or Mac. The X-HD card plugs into the HDX or HD Native card, and is seen as a Digi/Avid interface. It's not interfacing with the computer and no drivers or software is involved.
The only reason he'd need to access a Mac is if the card needs a firmware update.
Old 03-30-2014, 02:45 AM
zedhed's Avatar
zedhed zedhed is offline
Makes perfect sense!
Back when I first looked at the Omni/HDN, I couldn't get past the 8in/8out limitation of the Omni.
It never registered to me that you could use the second port on the Omni to connect an additional interface. Because I thought it was there if you wanted to add another HDX/HDN card for more DSP power...
Oh well, better late than never I guess.
But really, Avid could have done a better job advertising/detailing the expansion possibilities!
For future reference; reading the manual on a piece of gear one is intending to drop serious $$ on reveals the best research results.
For instance page 17 of the Omni manual states "You can add additional Pro Tools|HD audio interfaces to your Pro Tools|HD system using the Expansion port on the back of HD OMNI or using additional Pro Tools|HD cards. However,
Pro Tools supports only one HD OMNI in a single Pro Tools|HD system.".
Page 19 even has a pretty picture on how to do it
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 10-15-2014, 09:58 AM
lemieux lemieux is offline
I'd like to do the same thing as you but I am a bit confused about one thing. I've got an omni with HD Native and a Digi 192 I/O that I'd love to hook up for more ins and outs but I'm not sure which digilink cable to buy and how to hook it up... the manual says to connect the 192 to the Omni via the expansion port but I've heard that it's better to connect directly to the card. How do you have this connected and what version of PT are you running? Thank you so much!
Old 10-15-2014, 01:07 PM
Default ...add more inputs to OMNI
Just get a mini-digilink cable (similar to the one you must already have) and daisy chain them together. The wiring topology is largely driven by cabling convenience so a daisy chain is usually easier. This should be simple to do. I am not sure what would cause a holdup... just go get a cable and play. The documentation or any Avid dealer can get you the right mini-cable. Pay attention to any sync/clock needs... again the documentation is the place to start.
confused about omni inputs! PT user Pro Tools HDX & HD Native Systems (Mac) 12 05-12-2014 08:50 AM
Trim Optical Inputs on OMNI? dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 13 03-13-2013 02:34 PM
HD Omni inputs vin7 Pro Tools HDX & HD Native Systems (Win) 4 03-04-2013 09:36 PM
HD OMNi + 8 pre Adat how many inputs? Claudioska Pro Tools HDX & HD Native Systems (Mac) 6 02-18-2013 09:12 AM
OMNI question - # of inputs ianmiller Pro Tools HDX & HD Native Systems (Mac) 2 12-27-2011 08:34 PM
