Old 09-16-2008, 05:30 AM
akli akli is offline
Default MBOX2PRO and MACBOOK 2.4Ghz 13,3" compatibility
Hi I would like to change my laptop with a macbook (not a macbook pro too expensive for me) so I would like to know if the macbook 2,4 Ghz is compatible with the mbox2pro (firewire)
Thank you
Old 09-16-2008, 06:19 AM
Phil Ogden Phil Ogden is offline
Default Re: MBOX2PRO and MACBOOK 2.4Ghz 13,3" compatibility
http://www.digidesign.com/index.cfm?...id=51&eid=2724
http://www.myspace.com/philogg
Old 09-17-2008, 03:01 AM
Thank you for the answer. However, I've already checked the digidesign pages and they do not speak about the macbook 2,4ghz(the last one). So If someone can tell me very soon if Mbox2pro and of course ptLE74 works with macbook 2,4GHZ.
Thanks
Old 09-17-2008, 10:40 AM
nilsk nilsk is offline
I'm working on a MacBook pro 2,2 GHz, 15" monitor.
(Leopard; 10.5.4., PT 7.4.2.)
So I pretend it works on a 2,4 GHz / 13" aswell.
Best
Nils
Old 09-17-2008, 01:47 PM
DigiTechSupt's Avatar
Yes, it does.
If you just bought it, you will need Pro Tools LE 7.4.2, as newer machines only ship with Leopard. Do not install any version prior to 7.4.2, as it will cause problems.
Avid Audio Tech Support
Support FAQ
Old 09-18-2008, 05:51 AM
Hi thanks for the answer. I read some forum and it seems that the macbook (not the macbook pro) has only 1 firewire connector. So If I plug the mbox2pro , where could I plug the firewire harddrive. Does it work with a firewire hub?
Akli
Old 09-18-2008, 06:08 AM
Akli
'Daisy chain' - MB2P->FW400 HD-> Mac
Compatibility Alert: Pro Tools HD Native with 2011 MacBook Pro 17" Avid Pro Tools HDX & HD Native Systems (Mac) 1 06-27-2011 09:31 AM
HD Native with MacBook Pro 2011 17" Compatibility Alert Avid Technical Alerts 0 04-08-2011 11:11 AM
Mbox2Pro compatibility? MacBook Pro? glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-09-2009 08:42 AM
Macbook pro 2,4Ghz question tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-22-2008 11:36 AM
MacBook Pro 17" 2.4Ghz w/ mbox ethics585 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-27-2007 08:11 AM
