Old 02-27-2018, 07:50 PM
GTBannah GTBannah is offline
Default Re: Pro Tools 12 with Steinberg UR44
Did you install the "tools" that came with the UR-44? If you did, try un-installing them. Those might be the source of your problems.
I didn't install the tools, and everything is working fine here.
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 04-23-2019, 05:17 AM
mandrum mandrum is offline
Hi, I have a similar problem. I only have pro-tools 10, however, the same issues. I turn down the fader on the dsp mixer and then the sound that is heard is pro-tools only. The dsp mixer is actually quite handy as you get much less latency. So, when recording I actually have the opposite, I have the rec armed track fader within pro-tools turned to 0, and only use the the signal from dsp, then when mixing I turn the dsp channel down and mix using the pro tools mixer. You can keep the dsp mixer open. . A question from myself though...as signals are coming through both soft mixers, is the signal being split or compromised somewhere? Or are you just able to access the signal(in full) at two different places in the chain, the dsp mixer only letting you hear the sound?
Andy
UR44 play nice with PT 11 in Win 8.1? serstickman Third Party Interfaces 3 06-10-2014 10:29 AM
Steinberg MR816 CSX with Pro Tools ha2dorff Pro Tools 10 5 09-29-2013 10:50 AM
steinberg ur28m and pro tools 10 bissodj Windows 5 09-02-2012 06:14 AM
Pro Tools 10 with Steinberg CI 1 bobmonsour macOS 0 12-25-2011 10:55 AM
Pro Tools HD 7.3 with Steinberg x-click Makesound Pro Tools TDM Systems (Win) 0 07-10-2009 09:23 AM
