Old 05-09-2019, 07:19 PM
amagras amagras is offline
Default Search box closes after a second or so
If I'm not fast enough the search box will close before I can select the plugin I'm looking for. Anyone else seeing this?
amagrasmusic.com
Old 05-10-2019, 03:56 AM
Default Re: Search box closes after a second or so
Extremely happy to report it was because I had a DVD in the drive!!!
amagrasmusic.com
Old 05-12-2019, 01:22 PM
Well, turns out this is a real issue, I isolated the problem to using search from the plugin window, the insert works fine, see here:
https://youtu.be/5RPRVfa4nm4
amagrasmusic.com
Old 05-20-2019, 01:07 PM
Up and paging Mr @jeffro
amagrasmusic.com
Old 05-20-2019, 04:23 PM
jeffro's Avatar
jeffro jeffro is offline
Search from the plug-in is working fine here (same as from the insert) but I'm on macOS 10.13.6. Any other users seeing this? If so... system info please?
linkedin
Old 05-29-2019, 03:00 AM
I'm using Windows 10, Core i7 with 16gb RAM
amagrasmusic.com
Old 07-06-2019, 12:58 PM
This is still happening in 2019.6
amagrasmusic.com
Old 07-16-2019, 06:50 PM
Bump
amagrasmusic.com
Scorch 1.2 closes Fraser.Sims Avid Scorch (iOS) Forum 6 09-26-2013 01:00 AM
Cant save or closes noelooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-06-2009 01:34 PM
PT 7.4 closes jrosado458 Pro Tools TDM Systems (Mac) 3 12-20-2007 05:39 AM
PT LE 7.1 closes on digirewire.dpm tone matrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-21-2006 07:48 AM
And Pro Tools Just CLOSES??? MUSIKxDRUMR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2005 04:55 PM
