Old 03-30-2006, 11:55 PM
skylab001 skylab001 is offline
Default best way to deal with recording latency
I'm just curious what are some options for dealing with recording latency. Of Course there is Low latency monitoring, but what other ways are there to dealing with latency when recording. For example, I just brought over a session an HD system and it had 26 tracks already with plug ins and all. We just wanted to do a few guitar and vocal overdubs. The buffer on our LE system had to be set at 1024 to handle all the plugs and tracks or else the computer would bug out and not playback. But with a 1024 buffer we had quite a delay in the headphones.....so I'm wondering how other 002 LE users deal with this?
Old 03-31-2006, 12:18 AM
countach74 countach74 is offline
Default Re: best way to deal with recording latency
use only plugs that are absolutely necessary to the tracking process and lower your H/W Buffer to 128 or lower if you're doing percussive stuff... vocals can get away with 256 or more sometimes. depends on the artist. that's my 2 cents.
Old 03-31-2006, 12:39 AM
globaleric globaleric is online now
Temporarily deactivate as many tracks and plugins as possible (especially CPU intensive plugs like reverbs) while tracking those overdubs, so you can lower the buffer to a value around 128. You might also try to substitute plugins with some hardware effect box, if really necessary.
Mac Mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD
Presonus Quantum, Presonus FaderPort V2
Mojave 10.14.5, PT 2019.5, Waves Gold + additional selected plugins, some Massey plugins
Old 03-31-2006, 05:23 AM
bassntreble bassntreble is offline
fer' pete's sake....just bounce the whole damn thing down as a stereo mix except for any tracks you might want to punch into. at this point you have no plugins to content with and the mix sounds like it was intended out of the HD studio. drop the whole mess into low latency mode, record your overdubs. send the file back to the HD studio and have them import the new tracks into their session.....
done and done....
G5 1.8X2/3gigRAM/Mbox/7.4 (retired)
MBP C2D 2.4/4GigRAM/Mbox/8.0.1
iMac i7 3.4/16GigRAM/10.0.1
Old 03-31-2006, 05:33 AM
HotRats_Reloded HotRats_Reloded is offline
use an hardware mixer.
Old 03-31-2006, 05:54 AM
Banister Banister is offline
I've had some success using a Focusrite Twin Trac Pro pre amp... It has a "fold back" monitoring section built in.
It basically just allows me to offer no latency headphone monotoring for that channel. Not so hot for tracking drums, because it's only 2 channels, but using it for guitar or vocal overdubs it works great.
Old 03-31-2006, 01:14 PM
well first off we were not planning on returning to the Studio with the HD system(bands budget is way beyond what it can afford) so we've got to work with the LE system. I'm curious about using a hardware mixer. How exactly does this overcome the latency issue?
Old 03-31-2006, 06:11 PM
Slim Shady Slim Shady is offline
If you have an external preamp (or a Digi interface that has Insert Jacks on it) and hardware mixer, you just mult the output of the mic pre to the mixer (I do this using a compressor insert, one output sends back to the return on my Mbox, the other output goes to my mixer) - you then monitor via the mixer, which has your Microphone signal (pre-digi hardware) on one channel, and your PT output(s) on the other channels. You just mute the track you're recording to in PT as all monitoring is done outside the box.
Old 04-04-2006, 11:05 AM
athe athe is offline
oh my god ... i've been tring to work out how to monitor directly thro my 002 rack and have just joined this forum to ask the question ...and i find this thread .... ARE YOU TELLING ME I CAN'T DIRECTLY MONITOR WITH A 002 RACK .... I THOUGHT IT WAS SUPOSSED TO BE A BIT OF PRO KIT ...
sorry .... i just can't belive it ... what is the point ....why is it that digi always do things a little differently .... virtually every other bit of hardware at this price allows you to monitor directly ...
anyone want to buy a 002 rack ... virtually new !!
Old 04-04-2006, 12:03 PM
EGS's Avatar
EGS EGS is offline
...26 tracks already with plug ins and all. We just wanted to do a few guitar and vocal overdubs. The buffer on our LE system had to be set at 1024...
You should be able to run that many tracks/plugs at 128 buffer. Did you try ALL the Digi suggested setups/troubleshooting steps listed above? Describe you MAC/LE setup and maybe we can help. What is the session sample rate?
Desktop: Win 7 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / PT 9 / Focusrite LS56
Laptop: Win 7 / HP ProBook 4730s / i7-2630 / 8GB / PT 9 / U-PHORIA UMC1820
Info/Services link
LE to HD......Whats the deal with latency? The Dougfather Pro Tools TDM Systems (Mac) 6 08-17-2010 01:05 AM
Reminder how to deal with latency? Braveheart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-11-2009 03:49 PM
What's the deal with MIDI latency? Starcrash MIDI 3 03-29-2008 05:39 PM
Best way to deal with plug-in latency. Droog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-08-2006 10:00 AM
What's the deal with the 'latency' thing?? stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-22-2004 12:55 PM
