No signal to "Alt-Output" on XMON
Hi guys!
I`ve no output on the alternate-output on my D-Control. The main-outs are ok. Now I have connect an original Avid digisnake to the alternate-out but all 8 outs are dead... On the monitor-controlpanel I choose "Alt" but nothing. What is the problem, do you have any idea? Kind regards Mike |
Re: No signal to "Alt-Output" on XMON
What is the exact connections? Xmon needs specific setup
As I am sure you realize by now, the MAIN and ALT outputs are wired for surround sound. So if you are using a normal AVID DB25 to DB25 cable, you would use channels 1 and 5 in to get the sound from XMON and controlled by D-Control.
Also ensure that, if you have the Surround Panning module that, you have the (green) L & R buttons pushed under the two small (centered) LED displays and that its set to Solo and not Mute. Lastly, make sure you have the Sum button (Monitoring section - top left between two sets of rotary dials) pushed and activate the MAIN button below (MAIN also controls ALT) I hope this helps. Feel free to PM me if you need any additional help.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K Protools 2018.10 HD Native in 1 project suite Eristopher Music |
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" | electra1006 | MIDI | 0 | 06-18-2018 05:46 AM |
"No output device selected in Studio Monitor Express, using Default Output"?? | Focuret | Pro Tools 10 | 4 | 01-11-2014 02:31 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Channel I/O keeps loading old I/O and not "no input"/"no output" | Arve Gotfredsen | macOS | 4 | 02-12-2013 04:38 AM |
setting the "output to amps" outputs to "rig no cab" affected also the (xlr) outputs! | italianguitar | Eleven Rack | 15 | 03-20-2012 01:57 PM |
