Plugins making protools crash
Hello everyone,
Recently, my protools hasn't been tolerant with my plugs... Whenever i insert a plugin on an intrument track, protools crashes... I log my log reports that i can share but it's a .crash (don't know how to open it) I trashed my preferences. Didn't help. My CPU is at 7% ish when protools crashes. I don't know what to do. I used to have no problems at all with my plugins. (Arturia collection/ Waves plugins / Spectrasonics Omnisphere / Miroslav Philarmonik) Please help. I can't create and i'm getting depressed... Thank you all for your precious help!
Windows 10 PC Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 2.81GHz RAM 16,0Go Processor 64 bits Graphic card Geforce GTX1050 Audio interface : Mbox2mini / Asio4All Pro Tools 10 / 11 |
Re: Plugins making protools crash
Hi please try removing all the 3rd party plugins from PT folder and run a new session with only stuck plugins .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Thank you for your quick reply !
I uninstalled all my plugins except for the waves and the problem disappeared. Why are my plugins not supported anymore from one day to another?? does that mean i'm never gonna be able to use these plugins ever again ? I used to have like 15-20 tracks using different virtual instruments each without having any problems. This is so sad...
Hi i can't respond for 3rd party plugins but , maybe one update broke you compatility or maybe its only a simple application error or file corrupted . Unistalling and reinstalling one at time can help you identify the culprit if any .
p.s. The most of them uses ilok so remember to update ilok app too just in case .
Jesus,
Thank you for your help. I'll make sure to keep the forum posted on the tests i'm gonna do this week. Hopefully, i ll get a solid answer out of it. Kind regards,
Of course great ! Hope you can fix the issue
I've had similar issues in the past when installing a plugin will, for no apparent reason, cause PT to crash. Usually its with a plugin I've used multiple times for a long time, not some new one. Sometimes, simply rebooting PT and re-opening the session will solve the problem. If not, I have found that creating a new session and then importing the session data from the original session will solve it. When importing that way, I do one track at a time. That helps me figure out what might be causing the problem if there's another crash.
I know these kinds of problems can be a real kill joy! Good luck.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
PT10 on Win10 isn't supported. Not shure about PT11.
@DonaldM :
I tried with different sessions, new ones, existing ones. I don't think it's because my sessions are corrupted. Or it would mean that all of them are then. A reboot doesn't help here unfortunately... I'll make sure to try to import the session data. Fingers crossed! Thanks for your help ! @Ben Jenssen : Not sure i understand your comment... I have Protools 10 on my laptop. It workes flawlessly. Same for PT11.
Instead of uninstalling all the 3rd party plugins just cut them from the plugin folder and put them in a folder in the desktop, then you can place then in groups of 5-10 and see where the crashes start. Then you can remove the last 5 and put them back one by one until you find the faulty AAX
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Eucon making Pro Tools crash | garimpo | Artist Series | 6 | 02-10-2014 02:06 PM |
EuCon software v2.6.2 making my ProTools 10.1.2 crash | noeqplease | Artist Series | 0 | 05-03-2012 04:26 PM |
Waves plugins make ProTools crash! | Eydfinn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 02-25-2012 06:29 PM |
Plugins that crash / don't crash PT 8 not on Digi's compatibility grid | alex s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-27-2009 03:23 AM |
Is Pluggo making my system crash????? | Matt Coogan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-23-2002 06:42 AM |
