Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-18-2021, 04:11 PM
macmuse macmuse is offline
Default Opening project in regular PT after the Ultimate Trial is up
I'm about to switch over from the Ultimate trial to the regular PT that I bought. I didn't authorize regular yet on my iLok...the iLok and I are still running Ultimate which is about to expire.
I did do a couple test projects that I want to keep working on in Standard, without using any special Ultimate-only features.
Just want to make sure it should open in Regular version, or do I need to do anything special before authorizing it on my iLok (where it will then supersede Ultimate)? I just don't want to lose what I was working on.
Thanks.
Old 03-18-2021, 05:36 PM
Piotr Kubiak Piotr Kubiak is offline
Default Re: Opening project in regular PT after the Ultimate Trial is up
It will open without problem (and without multichannel busses, multi video clips etc.)
www.piotrkubiak.pl
Old 03-18-2021, 06:31 PM
Thank you! I wasn’t sure if I should render things out just in case it no longer loaded.
Do I need to actually install PT again to replace the Trial install, (this time from my account downloads), or will the Ultimate trial which is already installed revert to Regular once it sees the authorization on my ilok?
Old 03-18-2021, 07:02 PM
No you just update to the new license on your iLok. The software installs on disk are the same. Do *not* change anything there.
Old 03-18-2021, 09:49 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
There is no separate paid or trial PT app. There is not even a different Pro Tool standard and Pro Tools | Ultimate app. You technically always install the Pro Tools | Ultimate app, and the license on your iLok tells the app to give you access to all features or cripple the app and hide some features because you didn't pay Avid enough money.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
How to force opening regular Pro Tools with an Ultimate license bundle? XJENSEN Pro Tools 2019 19 07-09-2020 11:18 AM
Pro tools Trial - Not Ultimate? luckylukedg Pro Tools 2019 2 01-13-2020 03:28 PM
Random but regular error opening sessions in PT 12.7.1 take77 Pro Tools 12 3 06-10-2017 01:51 PM
ProTools 11 trial extension. In the middle of a project, trial expiring tonight bimbom macOS 2 02-22-2015 12:36 PM
project x vs. regular hard drive RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-13-2001 07:48 AM
