Skipping CD????
Okay, this is strange. Using LE 7.3.1 cs3 , Asus P5Pvm/Pentium D/ 2gigs ram, etc....
I USED to be able to throw a cd in either of my cd drives (1. Sony dvd-rom, 2. Sony Dvd dual-layer burner) and flawlessly audition the track before importing it. Without having changed anything, the reader started skipping during this operation, so I started extracting from the writer instead. It worked for about a week, and now, same problem...playback skips (reminiscent of trying to play I-tunes thru PT hardware). You can still extract audio and it works just fine, but what would cause the playback feature to suddenly crap out like this? Looked at my dma settings and everything is right where it should be. I'm confused..... |
Re: Skipping CD????
Drives headed south? I'll grant that it's a hell of a coincidence for both to go so close together, but can you get a loaner and swap one out?
Bob Without a song The day would never end |
Re: Skipping CD????
Yeah, wondered about that, but they'll both extract the aduio just fine....
Thanks for the input! |
Re: Skipping CD????
Did you ever find a solution to the skipping CD issue?
Cheers, Angelo Quaglia |
Re: Skipping CD????
Anyone check the dates on these posts?
Aug 1970 must be psychic, to repky BEFORE SW Rec and Bob L posted!
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Playback Skipping | thadjtig1 | Windows | 1 | 04-11-2013 05:11 AM |
Skipping during playback | ian Bourgal | General Discussion | 1 | 07-05-2009 11:54 AM |
skipping the optical | h1ntOn | Post - Surround - Video | 9 | 12-17-2008 05:17 PM |
skipping during playback | JAH FYAH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-25-2007 10:47 AM |
Skipping during playback | JAH FYAH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-25-2007 02:00 PM |
