Kontact Player no sound?
Hi. So I'm not getting my cinematic strings to make noise when I load it in my Kontact player in Pro Tools. I know that it's probably a routing issue but can someone walk me through it? Normally when I use other plugins (not through kontact) I just set up a "instrument track" and then insert the plugin into the track, but that isn't doing **** with the kontact player. Can someone help me set it up properly?
my specs: iMac 2020 3.8Ghz 8-core Intel core i7 processor Catalina OS ProTools 2020.12 Scarlett Focusrite + Saving to External Harddrive http://MayMcDonoughMusic.com |
Re: Kontact Player no sound?
First off make sure the library you're using can work with the Player version of Kontakt. Also make sure it can work with whatever revision of Player you have. Does it need version 5.x of Kontakt Player or 6.x? Not everything works with the Player version of Kontakt but may need the full version of Kontakt.
Okay - got that answered. Have PT show 'instruments' in the Edit screen and check that the routing is going to the instance of Kontakt in that track. Select the string library you want and try making some sounds via the built-in keyboard in the Kontakt gui. That will tell you if Kontakt is working right. You don't mention how you're triggering Kontakt - MIDI keyboard or what?
Make sure that Kontakt and your MIDI keyboard are on the same MIDI channel. Another thing is, and you should already know this - make sure you're not using a mono instance of Kontakt on a stereo instrument track. Did you try what I mentioned earlier about using the keyboard at the bottom of the Kontakt gui to see if you get any sound out? If you do that and you get sound that means output routing from Kontakt is okay. Do you have any other libraries you can use in Kontakt? If so do they work okay?
i tried routing it to kontact and i still didnt get sound. also there is no keyboard at the bottom of my kontact player.
Go to the top of the Kontakt Player gui and starting at about the middle of the top row you will see a floppy disc icon, to the right of that is a gear icon and click on the icon to the right of the gear icon. Select 'keyboard' and that will show the keyboard at the bottom. When you routed the output to Kontakt Player did you select the MIDI channel that the library is on? Normally in Kontakt the first instrument is on MIDI channel 1. Like I asked earlier - do you have any other libraries you can use in Kontakt player? You do know how to use Kontakt right? |
Reali-Banjo - Virtual Instrument - Kontact Player | YYR123 | Virtual Instruments | 19 | 11-30-2013 01:06 PM |
No sound on Gom player | David Khositashvili | General Discussion | 0 | 11-15-2008 12:13 PM |
Sound from Quicktime Player | harryk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 11-10-2007 11:09 PM |
Kontact Player & Sibelius w/002 | tbuttons | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-02-2005 07:09 PM |
Garritan Personal Orch/Kontact Player Problem | offcentermusic | Pro Tools TDM Systems (Mac) | 4 | 05-25-2004 08:54 AM |
