Old 04-05-2005, 06:39 PM
xraydelta1 xraydelta1 is offline
Default Midi control for OZONIC -M-audio and PT LE
Will the ozonic's knobs and sliders and joystick be able to control the onscreen plug ins easily? Will the ozonic also be a mini control surface for the mixer and/or plug ins? How well is the ozonic integrated into pro tools? This seems like it would be a handy control surface. But it would be a shame if none of the sliders worked, or you had to reprogram each slider manually through the ozonic's UI to emulate the signals of a cs-10 or motormix.
Old 04-05-2005, 06:40 PM
Default Re: Midi control for OZONIC -M-audio and PT LE
It will be up to the plug-ins to support the knobs on your M-Audio device... Wizoo plug-ins do support them.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-05-2005, 06:53 PM
What about the rtas plug ins and audiosuite plug ins? What about Digidesign made plug ins? What about the mixer? On the control surfaces, when you enable the automation controls on an insert/plug in the pots reference the controls you have enabled, as do their scribble strips. Is there any plans for this type of integration? What about enigma? Would that be able to also access the faders on the mix window?
Old 04-05-2005, 07:26 PM
I doubt it very much. If a plug-in developer decides to do it.. fine, but I doubt that it would be written into pro Tools and not work with Digidesign labeled equipment. The idea is, if you want a control surface, buy the Command-8 or 002.
Rail
Platinum Samples
M-Audio OZONIC - hw issue bopsi Pro Tools M-Powered (Mac) 0 01-15-2009 08:54 AM
Using faders on the M-Audio Ozonic Stickist MIDI 5 09-06-2006 05:42 AM
M-Audio Ozonic? VanGuard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-10-2005 04:06 PM
how to control PTMP using Ozonic Hogie Pro Tools M-Powered (Mac) 3 09-19-2005 04:14 AM
how to control PT using Ozonic Hogie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-14-2005 03:56 PM
