Boot Camp - Dual Boot, Dual Versions of PT LE?
I have a new iMac with Leopard on it. I have been running PT LE 7.3 on a 12" ibook with Tiger. I am running Boot Camp on the iMac and setting up XP. Although I want to get PT LE 8 eventually, buying the iMac means delaying the upgrade to PT 8.
For the time being, would it be possible to install PT LE 7.3 on the Windows partition and then once I can afford it, install PT LE 8 on the Mac Leopard partition? Since they are completely separate partitions, I am thinking this will work........ Thanks, bilco |
Re: Boot Camp - Dual Boot, Dual Versions of PT LE?
Pro Tools is not qualified to work on a Boot Camp Windows OS. There are mixed reports, but mostly there are problems. Please don't expect Pro Tools to work properly under Boot Camp.
Okay, I'll just hold off until I can afford the PT LE 8 download and I'll load it on the OS X partition.
Thanks for responding, bilco |
Was wondering if anyone has any positive feedback on PT8 with Bootcamp/Parallels or Fusion? Realize its not officially supported but with 7.4 there was alot of positive feedback even though unsupported.
I've been running both PTLE 7.4 and PTLE 8 successfully on a Mac Pro desktop with 2X dual cores under bootcamp. The bootcamp OS is Vista Home Premium. I've been able to record using the 003R without any problems. I have to use the rear firewire port to connect the 003R.
I´m trying this now.
We are two buddies running a studio together, and my friend is finally going to Learn PT. But he wants to keep all his windows plug-ins and also he doesn`t want to learn OSX at the same time. So I´m using the Rear firewire port on my Mac pro 4x3.0ghz with 5 gb ram. NOmater what buffer size I´m using I`m getting buffer errors and PT is asking me to not use anything else on the firewire bus. But I`m not using anything. SO wtf? ANybody have any ideas?
Stian Sylta Producer/Songwriter/Musician Sons Of Vanity on iTunes/Spotify MacBook Pro i7/Apogee One/Duet/ElevenR/Pro Tools 12 Preamps from UA, Mackie and Avid. Listening through Dynaudio, Genelec and ADAM |
Good news folks.
More people should test this to see if I`m way off. When using Digidesign LE-line soundcards in Windows XP on Bootcamp, I f`ve found now that if I disable the wireless internet connection on the Mac pro, everything works perfectly. But as soon as I enable wireless internet, there are pops, clicks and interrupts. I`ve also found that is happens when using other DAW`s in Boot Camp running windows xp. SO far this has been tested with SONAR 7 and ProTOols 7LE and 8 LE. Disabling the wireless adapter is easy, and now I`m set up with a shortcut on the quickstart menu in XP. Finally I can use all the sonar windows only VI plug-ins that I got with Sonar 7, in Pro Tools :) It would be great if others who where trying this could test my way and see if it helps them.
OT: PT-Win 7 / XP Dual-Boot; Question re: Win 7 Install, Boot Manager Files | taylor4814 | Windows | 1 | 02-16-2012 05:54 PM |
Boot Camp and RTAS Intel plugin versions | whoshotmikeg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-02-2006 07:38 PM |
Help with Dual Boot on Dual 1 ghz QuickSilver | new engineer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-13-2005 06:12 AM |
Dual Boot PT 6 & 5.1 | roberts | Pro Tools TDM Systems (Mac) | 0 | 05-19-2003 12:49 AM |
Configure Dual Boot on New dual 1.25?? | cliepe12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-10-2003 04:45 AM |
