Old 07-22-2020, 03:39 PM
TrentWilliams TrentWilliams is offline
Default 'Renicing' Pro Tools [solved]
Is there anyone out there who has experience with 'renicing' Pro Tools? I've changed the value to -20 with an AppleScript but it's resetting itself back to 0 after every process.
For example - I renice Pro Tools to -20; confirm it is indeed -20; open a plugin window; recheck the nice value; it's reset back to 0.
Looking for advice, if any.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 07-22-2020, 04:21 PM
Default Re: 'Renicing' Pro Tools
Opening a plugin does not renice Pro Tools for me.
Code:
$ ps -evlc | head -1
  PID STAT      TIME  SL  RE PAGEIN      VSZ    RSS   LIM     TSIZ  %CPU %MEM COMMAND            UID  PPID        F CPU PRI NI WCHAN              ADDR TTY
$ ps -evlc | grep 'Pro Tools\s*\d'
16702 S      2:20.43   0   0      0 10292984 752176     -        0  14.0  2.2 Pro Tools          501     1     4084   0  97  0 -                     0 ??
$ sudo renice -20 16702
16702 S<     2:24.21   0   0      0 10292984 752176     -        0  14.2  2.2 Pro Tools          501     1     4084   0  97 -20 -                     0 ??
$ ### Opened plugins and inserted more plugins...
16702 S<     2:33.31   0   0      0 10296448 759680     -        0  16.6  2.3 Pro Tools          501     1     4084   0  97 -20 -                     0 ??
Show us what exactly you are doing and looking at.
Old 07-22-2020, 04:26 PM
It would actually be impossible for PT to renice itself along the way as the process is not ran with root privilege. Admin user is not enough for renice
Old 07-22-2020, 04:35 PM
Actually that only goes one way. You only need root privilege to decrease priority below 0. Going the other way is easy, any process can do that it to itself.
Still this seems strange behavior and I would want to see what exactly is being looked at here.
Old 07-22-2020, 04:47 PM
Thanks for the reply Darryl,
Here's a screen capture : https://streamable.com/3ux0og
Old 07-22-2020, 05:22 PM
OK Trent, well it's not doing that for me. I tried multiple sessions and made sure I put the transport in play after opening the plugins etc. the same as you did.
I have a pretty clean install of 2020.5 on Mojave 10.14.6. (so close to yours).
So one wild ass guess here is a plugin might be doing something silly, and maybe not even the one you are opening.
If you want to get carried away we could scan all the plugin binaries for the setpriority() system call, but it's just easier for you do do a quick test there of moving all plugins out of the Pro Tools folder, trashing prefs, and testing with the session with just the default plugins that Pro Tools puts back.
Old 07-22-2020, 05:31 PM
Make sure you have not left applescript to do stuff, have it invoking a mangled renice command etc. I would get rid of all that/that might be left running. And test without it.
Old 07-23-2020, 01:35 AM
Hey Darryl! Thanks for your hard work in helping me figure this one out. It turns out there was another application open (App Tamer) which was prioritising nice values and interfering. Once I closed that app I was then able to set PT to -20 and have it stay there. I wrote an AppleScript which auto sets PT to -20 on launch so I don’t have to go through terminal every time 🍻
Old 07-23-2020, 01:37 AM
Default Re: 'Renicing' Pro Tools [solved]
Good to hear. But I doubt making PT not nice will make a difference. Would be happy to be proven wrong though
Old 07-23-2020, 12:15 PM
Thanks J,
Take it for a spin and report back? I ‘feel’ like it’s snappier and slightly more responsive but that could be placebo talking. *Plugins do seem a little faster to open?
The biggest performance increase I’ve seen in recent days is utilising a TimeMachine scheduler to automate backups outside of work hours. TM really hogs system resources, can not recommend enough.
FS: Pro Tools HD 8 + Pro Tools HD 9 + Pro Tools 9 Bundle iLOK license Delta Music Belgium Buy & Sell 1 02-27-2019 03:33 PM
