strange graphic behavior with plugin automation.
Hello
I'm experiencing issues with the plugins in PT9. Some plugins appear as if automation were enabled in its parameters... blue buttons and squares around them. I checked the automation dialog but nothing is added. I'd like to upload a pic so you can look at it. Where can I upload the photos so I can post the URL? Thanks. Ed. |
Re: strange graphic behavior with plugin automation.
I got the same problem.
Try uploading to imageshack or something like that.
Mac Pro Nehalem 8 core 8 GB Ram OS: 10.6.8 Pro Tools 10.0.1 RME Multiface II with Focusrite Octopre mkII |
Imageshack ok. I'm gonna put a pic there to show. Thanks.
[img=http://img810.imageshack.us/img810/4652/plugincontrolsautomatio.th.jpg]
In the above url is the pic for the issue with plugin controls automation. In the example if Digirack medium delay but the issue appears in several plugins in protools 9.0.2. Tell me if this happens to you and how can we report this to avid. Thanks. |
I'm assuming you're using a control surface of some sort. The blue indicates which parameters the control surface is controlling.
Thank you very much for your quick answer. Indeed I'm using PT 9.0.2 with the Command 8 Control Surface, I'm a new user of that control surface, so I'm at the learning stage yet.
Thanks, it's much more clear now. Ed. |
Strange automation behavior in 10.3 | meech | Pro Tools 10 | 5 | 10-29-2012 01:15 PM |
Strange (graphic?) bug with PTHD10 | handklang | macOS | 2 | 01-10-2012 03:09 PM |
Strange graphic anomalies in Protools 8.0.3 | czorro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-25-2010 03:42 AM |
Strange automation Behavior... Seems like AutoJpoin is Stuck | The Chinese | Pro Tools TDM Systems (Mac) | 5 | 08-29-2008 07:20 AM |
Strange waveform graphic | steve0916 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-13-2003 08:52 PM |
