12.4 Shortcuts
Can someone confirm that the shortcuts for MIDI Edit Window,Event Edit,and Score Window don't work properly on MAC (German Keyboard)?
Have to open Window Menu and than press the shortcut to make it work... Last edited by sam68; 12-24-2015 at 08:06 AM. |
Re: 12.4 Shortcuts
Confirmed on my system with U.S. keyboard.
The Midi Window shortcut works for me if I use Control+Equal (=) on the main section of my keyboard, but not with the numerical keyboard. Also, if I have keyboard focus on the edit window, (p) works for moving the edit selection up without the control key as it's supposed to do, but semicolon doesn't work to move down without holding the control key. And if I move down thru tracks in playlist view, it behaves like I was holding shift; the tracks stay selected. So instead of scrolling thru the tracks, one at a time, all the tracks remain selected.
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60 macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4 |
Re: 12.4 Shortcuts
Confirmed here too with UK Apple keyboard.
I've posted it as a bug on ideascale http://protools.ideascale.com/a/dtd/...en/223625-3779
Dave Marsden UK |
Re: 12.4 Shortcuts
Works here Protools HD 12.4 on El Capitan french keyboard
Re: 12.4 Shortcuts
Also, alt-D (Fade From Start of clip ) and alt-G (Fade To End of Clip) aren't working here with 12.4.
Re: 12.4 Shortcuts
The Bring to Front keyboard command is working erratically here here too!!
Dave Marsden UK |
Re: 12.4 Shortcuts
It never used to be. I just had to boot up 11 to check I wasn't going mad. PT11 : http://duc.avid.com/attachment.php?a...1&d=1454246552 PT12: http://duc.avid.com/attachment.php?a...1&d=1454246628 |
Re: 12.4 Shortcuts
I'm a Windows person and Pro Tools is not happy with anything except a US Keyboard language selection. Fortunately Win 8 & 10 allow different keyboard languages per application, so I've a UK physical keyboard with mostly UK language layout except for Pro Tools which uses a US layout. I wonder if there are similar issues/options of OSX?
Shortcuts on a MBP | midnightsun | macOS | 1 | 01-05-2013 11:03 AM |
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. | jessedtf | Pro Tools 10 | 6 | 10-24-2012 09:42 AM |
No num pad, what are the shortcuts? | boove | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-16-2009 07:47 PM |
Shortcuts? | bigassbeats | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-11-2004 01:22 PM |
Shortcuts | Camilo Orozco | ProControl, Control|24, Command|8 | 2 | 09-11-2000 03:01 PM |
