Old 10-05-2023, 11:52 PM
pasthq pasthq is offline
Default MIDI Channel Record Enable / No Recording
Hi there,
I put MIDI Channels into ProTools for my MIDI connection inbetween:
External Sequencer > MIDI Hub > External Synthesizer/Sampler
Yet I have to keep it record enabled to have MIDI go through the chain. When I record Audio it also records the MIDI.
Is there a way to set this up, so that it doesn't record the MIDI files?
Old 10-06-2023, 11:26 AM
Default Re: MIDI Channel Record Enable / No Recording
I'm confused here. So you don't want it to record? Then don't put the track into record? Maybe if you describe exactly what the end goal is, someone will have a good solution(I'm sure mine isn't that)
Old 10-07-2023, 12:59 AM
The problem is that the MIDI notes are not going through the MIDI interface when the MIDI channels are not record enabled.
I would love to not have the MIDI notes recorded.
Old 10-07-2023, 09:15 AM
Top Jimmy's Avatar
Is there a selection in the “Default Thru Instrument” setting that solves this problem for you? Look on the MIDI tab of the preferences for this setting.
James Cadwallader
Cannot record enable TWO midi sources at once Stormshadow2k Pro Tools 12 6 05-29-2017 01:47 PM
Not able to hear myself recording/Not seeing the (I) icon next to the Record enable mhills649 Getting Started 3 11-14-2014 02:57 PM
MIDI Record enable behavior DetroitT Pro Tools 10 6 06-29-2013 07:14 AM
MIDI vs AUDIO Record Enable HearInc macOS 4 04-04-2013 03:07 PM
Protools 7.4 midi record enable problem maisbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2007 08:33 AM
