Go Back   Avid Pro Audio Community > Dev > Pro Tools Scripting SDK Toolkit
Old 02-13-2023, 08:18 AM
PatrickCusack PatrickCusack is offline
Default Memory Allocation issue?
Team,
I see the folllowing in line 53 of CppPTSLC_DefaultRequest:
// TODO: replace with smart pointer
#define SETUP_CALLDATA() CallData* callData = new CallData();
There is a define for FREE_CALLDATA() on line 58, but is never invoked in the code.
Is this a likely suspect for the memory leak I have encountered when performing the following code in a timed loop?
HTML Code:
    while (true) {
        PTSLC_CPP::CommandRequest getTransportCommandRequest;
        getTransportCommandRequest.commandType = PTSLC_CPP::CommandType::GetTransportState;
        std::shared_ptr <PTSLC_CPP::GetTransportStateResponse> gtsr = client->GetTransportState(getTransportCommandRequest);
        sleep(1);
I apologize If I a missing something.
Patrick
Old 02-13-2023, 01:07 PM
Dmytro L's Avatar
Dmytro L Dmytro L is offline
Default Re: Memory Allocation issue?
Hi Patrick,
The team here has identified a couple of places with potential memory leak problems, we've been tracking this task as PT-297604. Thanks for bringing this up!
Dmytro
Old 02-13-2023, 02:40 PM
nsureit nsureit is offline
Originally Posted by Dmytro L View Post
Hi Patrick,
Dmytro
Dmytrol,
I hope you are safe and well. Thank you for helping keep Avid products up and running.
Take care!
Old 02-13-2023, 06:26 PM
Thanks for the acknowledgement. Is there a workaround to the code I posted? Or should I wait for updates?
Old 03-01-2023, 04:55 PM
rmajors's Avatar
rmajors rmajors is offline
Hi Patrick,
We don't have a specific patch that would fix this yet, though we are looking into it. I recommend waiting until we release an SDK update with a fix. If this is causing a critical failure in your application please let us know.
Also, a correction: PT-299612 will be the correct ID for this issue, which is a memory leak on the client app side.
Best,
Rob
Rob Majors
Avid Software Engineering
Memory allocation Rectifried Pro Tools HDX & HD Native Systems (Mac) 5 07-14-2011 08:06 AM
Memory Allocation 002 PT LE 6.7 sretepmada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2007 03:49 PM
Installation Memory Allocation Issue with Pro Tools Free (Message ID = -6008) mtbakerstu Digidesign Hardware & Software 0 02-01-2003 11:35 AM
DAE memory allocation...HELP! kalle74 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-02-2001 03:23 AM
Memory Allocation Dinkus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-20-2001 06:53 AM
