Go Back   Avid Pro Audio Community > Dev > Pro Tools Scripting SDK Toolkit
Old 02-10-2023, 07:19 PM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
Default PTSL fails to connect on Apple Silicon Native
When Pro Tools is running in Apple Silicon Native mode, PTSL fails to connect.
This is true on Monterey and Ventura.
With Pro Tools launched under Rosetta, the connection does work.
macOS13.2 or 12.5.1
PT2022.12
Here's the console output:
This appears to be logged by PTSLC_CPP::CppPTSLClient
Code:
[open] LAUNCH: Launch failure with -10652/ <FSNode 0x6000036bd420> { isDir = y, path = '/Applications/Pro Tools.app' }
This is the response to the OnResponseReceived() callback
Code:
header: taskID= CommandType=60 status: type=4 progress=0 error="[Error]: ProTools is not available yet."
And the CommandResponse returned from AuthorizeConnection() is nullptr
Old 02-11-2023, 07:22 AM
JamieHardt JamieHardt is offline
Default Re: PTSL fails to connect on Apple Silicon Native
In the client configutation, have you tried setting this?
Code:
config.skipHostLaunch = true;
Edit: The client's host launch code on MacOS uses system() and I'm pretty sure this is supposed to be sandboxed, it might not be able to see the "/Application" directory, depends on exactly how the build is signed or if it's not getting whitelisted out of Gatekeeper.
___
Jamie Hardt MPSE
Pro Tools Ultimate 2022.12.0
Mac OS X 12.6.2
Mac Pro (Late 2013)
Old 02-11-2023, 05:29 PM
The Cargo Cult
Pro tools is already running, so I think the "launch" error is just in response to PTSL client being unable to find/connect to PT.
Edit: confirmed that config.skipHostLaunch makes no difference.
The same connection works when PT is running under rosetta.
Have you seen PTSL working with PT under native Apple Silicon?
Old 02-12-2023, 12:21 PM
I haven't tried running on Apple Silicon, you could try running the python client to see what happens (I haven't tried running it on Apple Silicon either but some here might).
it's just odd that the error message would talk about filesystem paths and nodes, the scripting client doesn't talk to Pro Tools through the filesystem (at least not directly), it connects through a localhost TCP port.
___
Jamie Hardt MPSE
Mac OS X 12.6.2
Mac Pro (Late 2013)
Old 02-13-2023, 05:12 AM
jaydeesm jaydeesm is offline
lipo -info /Applications/Pro\ Tools.app/Contents/Frameworks/libPTSL.dylib
Non-fat file: /Applications/Pro Tools.app/Contents/Frameworks/libPTSL.dylib is architecture: x86_64
I wasted a few hours on this myself..
Old 02-13-2023, 09:17 AM
PatrickCusack PatrickCusack is offline
I am not too terribly familiar with CMake, but I don't think that it builds Arm64 builds. The framework it makes on my intel is only x86_64 which I discovered when trying to profile in Instruments. Instruments wouldn't let me profile unless the library included an arm64 build. I disabled the Apple Silicon target in Xcode and then Instruments allowed me to do some testing.
Old 02-13-2023, 10:26 AM
rmajors's Avatar
rmajors rmajors is offline
Hi all - apologies for the confusion. Pro Tools 2022.12 only supports the Pro Tools Scripting SDK on Windows and Mac Intel (including Rosetta) at this time. It is one of a few features still to be completed for full native Apple silicon support in Pro Tools. Work is in progress and we hope to support it in an upcoming release.
Rob Majors
Avid Software Engineering
Waves v14 for upcoming PT Apple Silicon Native info swethington AAX Plug-ins 13 11-18-2022 03:16 AM
Pro Tools and Native Apple Silicon use... lowthert macOS 10 07-24-2022 08:01 AM
More Apple Silicon misery Leon77 Pro Tools 2 06-23-2021 03:23 AM
Spectrasonics 2.7 – adds VST3 and native support for Apple Silicon M1 Macs unkJE Virtual Instruments 0 06-17-2021 09:49 PM
