Old 12-07-2014, 04:11 PM
asef@me.com's Avatar
[email protected] asef@me.com is offline
Default Dcommand and lost utility pann l led
Hi
Recently i found that my dcommand which it works less than 30 hours lost one of utility led command
When i checked that I found it works at the beginning when I switch it on
But it loss the command on it after a while like 5-10 min
May be it lost the connection when temperature goes up
Because I have to switch it off and wait till it lost the temperature and then it works for 5/10 min
May i ask you to help me pls?
Protools 11 HD,HD Native card, Icon D-Command, Omni, Sync IO, Symphony 6.5, Mac Pro
Old 12-07-2014, 06:16 PM
Craig F Craig F is offline
Default Re: Dcommand and lost utility pann l led
I think your going to need someone that can open it up and check the connections and solder joints
Thank you,
Craig
Old 12-07-2014, 06:29 PM
I can do it by myself , but I'm not sure that it can be solve by connection check. As I know it should be happened because of board or chip problem. I dont know if updating firmware can help
Lost all plugins after using Tech Support Utility to delete prefs & databases Kevbasskeys RTAS & TDM Plug-ins 4 07-09-2014 12:40 PM
Dcommand Bracket Kit postman56 ICON & C|24 0 03-21-2014 10:20 AM
Neyrinck V-Mon and Dcommand yazoo Post - Surround - Video 2 08-18-2012 11:12 AM
DCommand DCommand ICON & C|24 4 04-28-2010 10:03 AM
Where can I get docs for 7.2 w-Dcommand mtung ICON & C|24 4 08-28-2006 01:06 AM
