Won't Initialise Hardware in PT11 - PT10 fine!
So this is a weird one that instinctively I'm blaming on Avid. I have both 11.1.2 installed and 10.3.8. Both run fine on my old mBox 2 and Asio4All but my new focusrite Saffire Pro 24 DSP is not talking to Pro Tools 11. It was working at some point for sure but for the last few days whenever I get as far as hitting play in a project, PT11 will freeze for a second, and then say it could not initialise the saffire.
The saffire works fine in all other Daws including PT10 and Windows too. Using Windows 8.1x64. Please help, so frustrating! |
Re: Won't Initialise Hardware in PT11 - PT10 fine!
I thought that both those interfaces have valid drivers for 11. First thing I would try is dumping ASIO4ALL(which I consider to be the "last ditch" effort).
Hi holywoodj,
Can you please make sure you have the latest Saffire MixControl 3.4 from here: http://us.focusrite.com/downloads?pr...ire+PRO+24+DSP If you are still having trouble can you please contact us directly so we can gather more computer information? http://us.focusrite.com/answerbase/contact Best regards.
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
Ok. So I found a workaround, though not exactly a fix if this gives any more info. If I do the hold N trick on start up, Generic ASIO is selected and I can switch to Saffire. It then seems to work fine but if I restart PT11 without holding N, it won't initialise... Odd.
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
MCVCP70 error in PT10 PT11 works fine | PT8716 | Pro Tools 10 | 1 | 09-06-2013 06:19 AM |
iTunes, browsers not making sound, PT10 works fine | drwlxndr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-18-2013 08:29 PM |
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? | pein | Pro Tools M-Powered (Win) | 2 | 10-07-2009 12:01 AM |
Mac gurus Help!! HD initialise problem | Mike F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-15-2003 06:39 PM |
