Old 03-26-2013, 08:38 AM
Becharax's Avatar
Becharax Becharax is offline
Default Fender Mustang AMP 1 & Pro Tools 10
Hello Guys,
I just bought this amp for my guitar ... for anyone who already has ... how do you guys connect it to use with your Pro Tools Rig ??
Please advise...
Regards,
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 03-26-2013, 11:03 AM
strangedogs strangedogs is offline
Default Re: Fender Mustang AMP 1 & Pro Tools 10
I also just got a Mustang i V2. I know there's few presets in FUSE (on the Web) to download called "EMPTY" - they're basically just a dry preset with no effects, etc - turn the volume up as it's usually set on ZERO. On the front of the 11 run a cable to the input on the Mustang. I haven't tried it yet though.
EDIT: Works fine! Load the EMPTY preset into fuse (I saved it for easy access) - plugged my ax into the 11R - ran another guitar cable from "to amp" on the 11 - plugged it into the Mustang and turned the Master Volume up on the amp. Works! Sounds great through headphones.
Old 03-26-2013, 11:24 AM
You can use this as a USB interface, not what you want if you have an existing PT rig. You can use the headphone/line output straight into an interface, or just mic the cab the old fashioned way. You should see what sounds best for what you are trying to do. Lots of things affect this decision, like what exactly is your interface, if you can play/record the amp at decent volume, how the guitarist wants/expects to monitor what they are playing, etc.
Old 03-27-2013, 12:53 AM
Becharax's Avatar
I have the mackie onyx 1640i .... so i would connect the amp to one of the inputs on the mackie ...
should i use the AUX or Headphones on the amp ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-27-2013, 01:59 AM
Becharax's Avatar
for micing the cabinet you really need a decent mic and I am not into Live recording :) just want to get the signal coming out of the amp directly to my DAW :)
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-27-2013, 02:12 AM
OK, but like everybody else you just start with a ~$100 SM57 or SM58 basic dynamic mic. Nothing high end there.
Old 03-27-2013, 02:28 AM
Becharax's Avatar
aha .... but what about mic placement etc ... i dunno ... you seem much against the headphones jack !
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-27-2013, 03:25 AM
ChuckS ChuckS is offline
If it's basically the same driver as the Fender Floor, configure the Pro Tools Aggregate I/O in Audio MIDI Setup to include the Mustang Amplifier (and whatever other audio devices you are using) and then use the aggregate device for PT.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 03-27-2013, 03:31 AM
Becharax's Avatar
OK Now we're talking :)
What's the Fender Floor ??
and when I configure this how will i be able to use it ?? it will show in the I/O of each Audio Track ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Old 03-27-2013, 03:55 AM
The Floor is the pedal version of the amp. Yes it will show up in the I/O, but you'll have to reconfigure the I/O for the aggregate. The naming in aggregate devices is weak at best. I think the only limitation is the Fender driver only supports 44.1k.
Fender Telecaster Stig Eliassen Eleven Rack 12 03-02-2013 03:40 PM
Fender Mustang Amp With Pro Tools 9? 21placebo Pro Tools 9 15 02-15-2013 07:23 PM
Fender Amplitube and Pro tools PaPa Ray Windows 3 08-27-2012 08:01 AM
FYI - Fender Mustang IV works GREAT with Eleven Rack! Justin1524 Eleven Rack 9 06-12-2011 06:53 PM
Controlling Fender Cyber Twin in Pro Tools ceowens MIDI 1 05-12-2004 01:25 PM
