Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 02-13-2013, 10:36 AM
Old School Audio Guy Old School Audio Guy is offline
Default Using PT10 native without the native card
HI
I already have my Lynx AES cards and interfaces and would like to get more I/O up to 64 which is what you can get with the Lynx in most other programs that use ASIO can you do this with PT10 HD because you can only have 32 I/O in PT 10 Native Or do I need to get the Native card?
Thanks
Old 02-13-2013, 10:45 AM
nst7 nst7 is offline
Default Re: Using PT10 native without the native card
You would need both the HD Native card and an HD interface (or 3rd party interface that hooks up via Digilink, such as the Lynx Aurora or Apogee Symphony IO).
The card by itself won't do anything. You would also need the HD 10 license on your Ilok, not just regular PT and Complete Toolkit. The HD software license comes with the HD Native system.
Old 02-13-2013, 02:34 PM
OK Thanks that answers my question with the HD native card is it still using ASIO?
Old 02-13-2013, 08:06 PM
I'm not sure what you're asking here.
Old 02-13-2013, 10:28 PM
No, it's their own drivers.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 02-14-2013, 09:17 AM
Thanks that is what I wanted to know do you know if programs that use ASIO can see the Avid Native card? but will use the Avid drivers. I use Sequoia for Mastering and it also uses VST Plugs so I wanted to use the same machine for both so I am researching if Sequoia will see the Native card and the PT Drivers.
Old 02-14-2013, 11:11 AM
Yes, you can use the HD Native as the interface/soundcard with Sequoia and other programs like Cubase or any ASIO compatible software.
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
Two PT10 HD Issues on HD Native Card. TimNielsen macOS 38 11-06-2012 04:24 AM
From PT8 HD1 to PT10 native quefijo macOS 8 07-06-2012 09:28 PM
HD Native card wont update firmware on PT10 after several atempts NicoDS macOS 15 03-05-2012 12:10 PM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
