Two PT10 HD Issues on HD Native Card.
Could use some help.
First, I just installed a new HD Native card, 10.7.2 Lion, and PT10 HD. This is replacing an HD3 system. First, every time I launch ProTools I get the darn 'Do you want to allow PT to accept incoming access' thing. Annoying. Second, more importantly, I'm plagued right from the bat with -9092 errors. Basically they say: "Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue." I'm using internal sync, and am not even trying to play much. In fact I've had it happen on an empty session!! CPU usage is literally at 0% or 1 to 2% max, so it's not CPU overloading. Something is clearly conflicting. I've searched but I can't seem to find any ideas. My system, an 8-Core Harpertown Mac, 10 gigs of Ram, Lion 10.7.2 I do have both an eSATA card and an SAS card in my machine, but never had any issues with them. This is a real bummer. I love the setup otherwise, but at the moment it's unusable... |
Re: Two PT10 HD Issues on HD Native Card.
Playback Engine settings with HD Native, max processors minus one or perhaps two processors for offline duties. H/W Buffer Size for now try 1024 Samples. CPU Usage max to 99%. What is your Session Sample Rate? 48kHz. Also what is running in the background, any programs or services that can be shut down? Is this computer on the Internet? Do you have partitions?
Aaron Mulqueen - 001 HD Native |
"Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue. If this occurs often, verify your sync cables or try changing the HW Buffer Size setting in the Playback Engine dialog. In most cases a larger HW buffer size will prevent the problem. (-9129)"
same here, when i go under 1024buffer same here, also when i open a plugin during play (1024 buffer) CPU set to 99% Processors set to 14 (16 available) 44.1kHz any idea? switch today from HD3 accel to HD Native Mac Pro 8core Westmere 8GB Ram OSX 10.6.8 Pro Tools 10 HD Native Avid HD I/O |
Judging by all the other users in our boat there appears to be a real issue with the Harpertown Mac Pro and the HD Native card. I was so fed up with things earlier this week that I actually ordered a new 6 Core 3.33 GHz, 2010 Mac Pro and intend to compare it side by side to the 2008 machine. It arrives next week, so I'll keep you posted. The interesting thing about all of this is that when I reinstall my TDM core card, all the errors disappear instantly.
Lynx Hilo Thunderbolt 2013 Retina Macbook Pro 2.7 16 GB of RAM PTHD 11.3.1 OSX 10.10.1 Last edited by drumster; 11-12-2011 at 10:41 AM. Reason: typo |
My 'guess' would be that the audio data is handled differently with a DSP based system.
Guys, can you detail what programmes and/or drivers, peripherals, Network adapters, storage, partitions, etc., please?
This is a real drag. Yes, my previous config was a TDM HD3 setup in a Magma Chassis, and I certainly never had any issues like this. I don't have time right now to figure out every single thing that could possibly be conflicting.
But this doesn't bode well at all! Please do keep me posted. Am planning on a new machine once the new Mac Pros are released (if they are!). But this thing should work. I'm getting the error with NOTHING playing, even in an empty session. No rhyme or reason at all. Hardware buffer has no effect. |
We will not make progress here, if you can not answer questions asked.
I didn't say I couldn't answer them, just not that second! I will try and post more. I am however an insanely busy professional with a film in post, and so I don't have hours to spend right now ripping apart my system trying to figure out why the new HD Native card is causing constant errors while the HD TDM that it replaced worked perfectly.
I'm not demanding instant answers, and when I can elaborate on the system I will! |
Tim,
have you ever fixed these issues? Oliver |
Using PT10 native without the native card | Old School Audio Guy | Pro Tools HDX & HD Native Systems (Win) | 6 | 02-14-2013 11:11 AM |
Venue + mix rack + hdx card + pro tools hd native card ? | hart07 | VENUE Live Sound Systems | 2 | 05-23-2012 12:02 PM |
HD Native card wont update firmware on PT10 after several atempts | NicoDS | macOS | 15 | 03-05-2012 12:10 PM |
Bounce to MP3 Issues on PT10|HD Native | timecode | Pro Tools HDX & HD Native Systems (Win) | 6 | 11-07-2011 03:48 PM |
HD Native Card Possibly Fried My Graphics Card | witrelo | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-14-2011 11:46 AM |
