Old 06-01-2011, 06:15 PM
mixmania mixmania is offline
Default Sync, wordclock issue
I am having what seems to be wordclock syncing issues. i am connecting a Telos NX6 via AES into a 96I/O. There is no wordclock in or out on the Telos only 2 AES ins and 2 AES outs. I'm getting clicks and pops.
Set up for the HD rig is as follows:
A) Venue Profile - into - 1)HD core Accel and 2) second HD Accel card
B) 96 I/O - into 3) third HD Accel card
Wordclock is fed from the Venue Profile into the 96 I/O Loop sync which is then fed from the 96I/O Loop Sync OUT into the SYNC I/O loop sync.
Any thoughts?
Old 06-02-2011, 11:26 AM
Default Re: Sync, wordclock issue
Issue resolved.
Old 06-02-2011, 04:14 PM
formfunction formfunction is offline
Originally Posted by mixmania View Post
Issue resolved.
It is generally good DUC form to share the resolution, mainly to help out the next guy with the same/similar issue.
But.. my guess is that loopsync was your issue from the venue? should have fed the WC connections on the 96i/o instead? Just a guess, having never ran a Venue, but knowing that the loopsync is for AVID stuff..?Thanks, ff
Old 06-02-2011, 07:57 PM
Absolutely, just did not have time to earlier.
The problem was the clock source setting in the Telos NX6 which is not accessible by the front panel. It has to be set via the network using a web browser.
Wordclock sync via SPDIF with any interface? nucelar Pro Tools 9 3 04-18-2011 08:49 AM
Mbox wordclock sync? letrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-28-2004 03:38 PM
PT Sync with wordclock mongiver Pro Tools TDM Systems (Win) 1 02-10-2004 05:56 AM
MTP vs DTP and spdif wordclock sync to 001/PTle rdatman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-22-2002 12:33 AM
Question regarding Wordclock sync... chengod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-16-2002 10:13 PM
