Reference levels-quick question
Hi everyone,
we've been asked to do quite an important surround mix for something and they've stated: "Audio can be -20 DB OVU (full-bit rate), but do not exceed the peak." do they mean master so the peaks hit -20DBFS. I presume that's what it means but it's written in an odd way and i wanted to check with people more in the know with this sort of stuff. Thank you |
Re: Reference levels-quick question
No. I think it means average audio can be around -20 dbFS (= 0 VU if you're in the US), peaks usually are 10dB over that (-10dbFS) if it's for broadcast. Otherwise peaks could go up to 0dBFS, but that's LOUD! (103dBSPL!!) Never came across audio that had to have peaks at -20dbFS.
Do you have experience with mixing (surround)? If it's as important as you say you might consider having a pro sit with you...
i am studios b.v. www.iam-studios.com audio post production. music composition. sound design |
Ah, that was my second guess. But as it doesn't state what the peaks should be other than the -20DBFS figure i thought it must've been referring to that.
Yeah, i've lots of experience with surround, just not reference levels... i left films to do games a few years back and had forgotten how things worked in the crazy film/tv land thanks for the help |
Reference levels for DV output? | JonesH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-17-2007 07:13 AM |
can someone help me understand reference levels | LL Lush | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-27-2004 10:35 AM |
EQ quick reference... | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-12-2002 09:04 AM |
Reference Levels ( -20=0 vs the Dynamic Range) | Diegux | Tips & Tricks | 11 | 03-31-2002 10:27 AM |
Calibration/Reference levels | Mark Wheaton | Pro Tools TDM Systems (Mac) | 8 | 10-03-2001 10:36 AM |
