Dcommand and lost utility pann l led
Hi
Recently i found that my dcommand which it works less than 30 hours lost one of utility led command When i checked that I found it works at the beginning when I switch it on But it loss the command on it after a while like 5-10 min May be it lost the connection when temperature goes up Because I have to switch it off and wait till it lost the temperature and then it works for 5/10 min May i ask you to help me pls?
Protools 11 HD,HD Native card, Icon D-Command, Omni, Sync IO, Symphony 6.5, Mac Pro |
Re: Dcommand and lost utility pann l led
I think your going to need someone that can open it up and check the connections and solder joints
I can do it by myself , but I'm not sure that it can be solve by connection check. As I know it should be happened because of board or chip problem. I dont know if updating firmware can help
Lost all plugins after using Tech Support Utility to delete prefs & databases | Kevbasskeys | RTAS & TDM Plug-ins | 4 | 07-09-2014 12:40 PM |
Dcommand Bracket Kit | postman56 | ICON & C|24 | 0 | 03-21-2014 10:20 AM |
Neyrinck V-Mon and Dcommand | yazoo | Post - Surround - Video | 2 | 08-18-2012 11:12 AM |
DCommand | DCommand | ICON & C|24 | 4 | 04-28-2010 10:03 AM |
Where can I get docs for 7.2 w-Dcommand | mtung | ICON & C|24 | 4 | 08-28-2006 01:06 AM |
