Old 01-08-2010, 01:31 PM
audioluche audioluche is offline
Default All Event markers to warp markers?
I search the 7.4 manual but i dont find a way to do what i want.
Is there a way to turn ALL event markers of a track to warp markers?
I dont want to quantize, the tracks that i am editing right now are not on a click.
I just want to turn all the event markers in one quick operation so i could just listen to the track and warp here and there without having to add a warp marker in warp view, it would be faster.
Am i missing something?
Thanks
Luc
Old 01-08-2010, 01:42 PM
BaileyBass BaileyBass is offline
Default Re: All Event markers to warp markers?
Originally Posted by audioluche View Post
Thanks
Luc
Use Quantize, but set your strength at 0%.... Everything stays.. SB
Old 01-08-2010, 06:26 PM
Hi Bailey,
Thanks for the input.
I tried with the strenght at 0% but the transient seems to be quantized even if it's at 0. And i dont see the warp markers after ...?
any idea?
Thanks!
Luc
Old 01-08-2010, 07:00 PM
Hi Bailey,
any idea?
Thanks!
Luc
hmmm... Are you selecting a portion of audio? 2 bars, a phrase?
Just tested it here and it works as it should, placing a warp marker on every transient, where there was an analysis marker... with strength set at 0, nothing moves.
You are using the quantize window (option-0) right?.. under options (in that window)check the strengh box then pull the slider all the way to zero. And you are in WARP VIEW,
good luck,.. SB
Old 01-10-2010, 03:34 AM
scottgreiner scottgreiner is offline
I usually quantize by 2%, then "remove warp".
Old 01-10-2010, 06:37 AM
Sean Russell Sean Russell is offline
Try this:
In event view (not warp view) do an option-5 and then set the event sensitivity. Helpful if you're EA'ing bass, and don't want all the extra ridiculous markers. (I hope they sort that out).
Then pull up quantize (option-0) and select 1%.
This won't move anything more than a tick or two. It's a very fine amount, and there should be no noticeable difference.
... but does it help the chorus?
Old 01-10-2010, 08:59 AM
Originally Posted by Sean Russell View Post
T. Helpful if you're EA'ing bass, and don't want all the extra ridiculous markers. (I hope they sort that out).
Yes I concur. What I don't understand is why they have a sensitivity parameter that goes from 0 to 100 but basically nothing happens from 0 to around 90. I end up having to get rid of the analysis markers by hand.
Old 01-10-2010, 09:00 AM
That's what I normally do but I came a cropper earlier on when I "removed warp" as I'd sped the track up 1bpm. We really need a "convert all analysis markers to warp markers" function.
Old 01-10-2010, 10:12 AM
good luck,.. SB
OOPs. I forgot to add that I set Randomize to 1% for the Strength to work at 0. I figured that with strength at zero, then Randomize would not function. I just tested it by pushing Random up... and they do move. So much for "figuring"
I can see zero mvmt at random 1%. I will look further and closer later. Either way the mvmt is less than minescule, insignificant, particularly when dealing with Humans! SB
Old 01-11-2010, 06:02 AM
Ok now it works!
Thanks everybody!
Yes, a convert analysis marker to warp marker would be nice, but that's a good alternative,
Cheers
Luc
Cut at warp markers, is this possible chaeffersa Tips & Tricks 3 12-20-2013 07:00 AM
Lining Up Warp Markers completeidiot23 Pro Tools 10 1 06-14-2012 09:38 PM
How to turn all Event Markers into Warp Markers ??? fman Pro Tools TDM Systems (Mac) 15 04-29-2011 01:46 PM
PT8 Warp markers converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2009 03:40 AM
Warp Markers Inconsistent Mount Royal Pro Tools TDM Systems (Mac) 0 04-17-2008 08:09 PM
